RTEMS 6.1
__IO uint32_t RSR
__IO uint32_t AHB3ENR
__IO uint32_t AHB1ENR
__IO uint32_t AHB2ENR
__IO uint32_t AHB4ENR
__IO uint32_t APB3ENR
__IO uint32_t APB1LENR
__IO uint32_t APB1HENR
__IO uint32_t APB2ENR
__IO uint32_t APB4ENR
uint32_t RESERVED9
__IO uint32_t AHB3LPENR
__IO uint32_t AHB1LPENR
__IO uint32_t AHB2LPENR
__IO uint32_t AHB4LPENR
__IO uint32_t APB3LPENR
__IO uint32_t APB1LLPENR
__IO uint32_t APB1HLPENR
__IO uint32_t APB2LPENR
__IO uint32_t APB4LPENR
uint32_t RESERVED10 [4]
Field Documentation
◆ AHB1ENR
__IO uint32_t RCC_Core_TypeDef::AHB1ENR
RCC AHB1 peripheral clock register, Address offset: 0x08
◆ AHB1LPENR
__IO uint32_t RCC_Core_TypeDef::AHB1LPENR
RCC AHB1 peripheral sleep clock register, Address offset: 0x40
◆ AHB2ENR
__IO uint32_t RCC_Core_TypeDef::AHB2ENR
RCC AHB2 peripheral clock register, Address offset: 0x0C
◆ AHB2LPENR
__IO uint32_t RCC_Core_TypeDef::AHB2LPENR
RCC AHB2 peripheral sleep clock register, Address offset: 0x44
◆ AHB3ENR
__IO uint32_t RCC_Core_TypeDef::AHB3ENR
RCC AHB3 peripheral clock register, Address offset: 0x04
◆ AHB3LPENR
__IO uint32_t RCC_Core_TypeDef::AHB3LPENR
RCC AHB3 peripheral sleep clock register, Address offset: 0x3C
◆ AHB4ENR
__IO uint32_t RCC_Core_TypeDef::AHB4ENR
RCC AHB4 peripheral clock register, Address offset: 0x10
◆ AHB4LPENR
__IO uint32_t RCC_Core_TypeDef::AHB4LPENR
RCC AHB4 peripheral sleep clock register, Address offset: 0x48
◆ APB1HENR
__IO uint32_t RCC_Core_TypeDef::APB1HENR
RCC APB1 peripheral clock High Word register, Address offset: 0x1C
◆ APB1HLPENR
__IO uint32_t RCC_Core_TypeDef::APB1HLPENR
RCC APB1 peripheral sleep clock High Word register, Address offset: 0x54
◆ APB1LENR
__IO uint32_t RCC_Core_TypeDef::APB1LENR
RCC APB1 peripheral clock Low Word register, Address offset: 0x18
◆ APB1LLPENR
__IO uint32_t RCC_Core_TypeDef::APB1LLPENR
RCC APB1 peripheral sleep clock Low Word register, Address offset: 0x50
◆ APB2ENR
__IO uint32_t RCC_Core_TypeDef::APB2ENR
RCC APB2 peripheral clock register, Address offset: 0x20
◆ APB2LPENR
__IO uint32_t RCC_Core_TypeDef::APB2LPENR
RCC APB2 peripheral sleep clock register, Address offset: 0x58
◆ APB3ENR
__IO uint32_t RCC_Core_TypeDef::APB3ENR
RCC APB3 peripheral clock register, Address offset: 0x14
◆ APB3LPENR
__IO uint32_t RCC_Core_TypeDef::APB3LPENR
RCC APB3 peripheral sleep clock register, Address offset: 0x4C
◆ APB4ENR
__IO uint32_t RCC_Core_TypeDef::APB4ENR
RCC APB4 peripheral clock register, Address offset: 0x24
◆ APB4LPENR
__IO uint32_t RCC_Core_TypeDef::APB4LPENR
RCC APB4 peripheral sleep clock register, Address offset: 0x5C
◆ RESERVED10
uint32_t RCC_Core_TypeDef::RESERVED10
Reserved, 0x60-0x6C Address offset: 0x60
◆ RESERVED9
uint32_t RCC_Core_TypeDef::RESERVED9
Reserved, Address offset: 0x28
◆ RSR
__IO uint32_t RCC_Core_TypeDef::RSR
RCC Reset status register, Address offset: 0x00
The documentation for this struct was generated from the following files:
