RTEMS 6.1
RCC_CRSSynchroInfoTypeDef Struct Reference
RCC_CRS Synchronization structure definition. More...
#include <stm32h7xx_hal_rcc_ex.h>
uint32_t ReloadValue
uint32_t HSI48CalibrationValue
uint32_t FreqErrorCapture
uint32_t FreqErrorDirection
Field Documentation
◆ FreqErrorCapture
uint32_t RCC_CRSSynchroInfoTypeDef::FreqErrorCapture
Specifies the value loaded in the .FECAP, the frequency error counter value latched in the time of the last SYNC event. This parameter must be a number between 0 and 0xFFFF
◆ FreqErrorDirection
uint32_t RCC_CRSSynchroInfoTypeDef::FreqErrorDirection
Specifies the value loaded in the .FEDIR, the counting direction of the frequency error counter latched in the time of the last SYNC event. It shows whether the actual frequency is below or above the target. This parameter must be a value of RCCEx CRS FreqErrorDirection
◆ HSI48CalibrationValue
uint32_t RCC_CRSSynchroInfoTypeDef::HSI48CalibrationValue
Specifies value loaded in HSI48 oscillator smooth trimming. This parameter must be a number between 0 and 0x3F
◆ ReloadValue
uint32_t RCC_CRSSynchroInfoTypeDef::ReloadValue
Specifies the value loaded in the Counter reload value. This parameter must be a number between 0 and 0xFFFF
