RTEMS 6.1
RCC_CRSInitTypeDef Struct Reference
RCC_CRS Init structure definition. More...
#include <stm32h7xx_hal_rcc_ex.h>
uint32_t Prescaler
uint32_t Source
uint32_t Polarity
uint32_t ReloadValue
uint32_t ErrorLimitValue
uint32_t HSI48CalibrationValue
Field Documentation
◆ ErrorLimitValue
uint32_t RCC_CRSInitTypeDef::ErrorLimitValue
Specifies the value to be used to evaluate the captured frequency error value. This parameter must be a number between 0 and 0xFF or a value of RCCEx CRS ErrorLimitDefault
◆ HSI48CalibrationValue
uint32_t RCC_CRSInitTypeDef::HSI48CalibrationValue
Specifies a user-programmable trimming value to the HSI48 oscillator. This parameter must be a number between 0 and 0x3F or a value of RCCEx CRS HSI48CalibrationDefault
◆ Polarity
uint32_t RCC_CRSInitTypeDef::Polarity
Specifies the input polarity for the SYNC signal source. This parameter can be a value of RCCEx CRS SynchroPolarity
◆ Prescaler
uint32_t RCC_CRSInitTypeDef::Prescaler
Specifies the division factor of the SYNC signal. This parameter can be a value of RCCEx CRS SynchroDivider
◆ ReloadValue
uint32_t RCC_CRSInitTypeDef::ReloadValue
Specifies the value to be loaded in the frequency error counter with each SYNC event. It can be calculated in using macro HAL_RCC_CRS_RELOADVALUE_CALCULATE(__FTARGET, FSYNC) This parameter must be a number between 0 and 0xFFFF or a value of RCCEx CRS ReloadValueDefault .
◆ Source
uint32_t RCC_CRSInitTypeDef::Source
Specifies the SYNC signal source. This parameter can be a value of RCCEx CRS SynchroSource
