RTEMS 6.1
RAM_ECC_Specific_Registers. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t SR
__IO uint32_t FAR
__IO uint32_t FDRL
__IO uint32_t FDRH
__IO uint32_t FECR
Field Documentation
◆ CR
__IO uint32_t RAMECC_MonitorTypeDef::CR
RAMECC monitor configuration register
◆ FAR
__IO uint32_t RAMECC_MonitorTypeDef::FAR
RAMECC monitor failing address register
◆ FDRH
__IO uint32_t RAMECC_MonitorTypeDef::FDRH
RAMECC monitor failing data high register
◆ FDRL
__IO uint32_t RAMECC_MonitorTypeDef::FDRL
RAMECC monitor failing data low register
◆ FECR
__IO uint32_t RAMECC_MonitorTypeDef::FECR
RAMECC monitor failing ECC error code register
◆ SR
__IO uint32_t RAMECC_MonitorTypeDef::SR
RAMECC monitor status register
The documentation for this struct was generated from the following files:
