RTEMS 6.1
QUAD Serial Peripheral Interface. More...
#include <stm32h742xx.h>
Data Fields | |
| __IO uint32_t | CR |
| __IO uint32_t | DCR |
| __IO uint32_t | SR |
| __IO uint32_t | FCR |
| __IO uint32_t | DLR |
| __IO uint32_t | CCR |
| __IO uint32_t | AR |
| __IO uint32_t | ABR |
| __IO uint32_t | DR |
| __IO uint32_t | PSMKR |
| __IO uint32_t | PSMAR |
| __IO uint32_t | PIR |
| __IO uint32_t | LPTR |
| __IO uint32_t QUADSPI_TypeDef::ABR |
QUADSPI Alternate Bytes register, Address offset: 0x1C
| __IO uint32_t QUADSPI_TypeDef::AR |
QUADSPI Address register, Address offset: 0x18
| __IO uint32_t QUADSPI_TypeDef::CCR |
QUADSPI Communication Configuration register, Address offset: 0x14
| __IO uint32_t QUADSPI_TypeDef::CR |
QUADSPI Control register, Address offset: 0x00
| __IO uint32_t QUADSPI_TypeDef::DCR |
QUADSPI Device Configuration register, Address offset: 0x04
| __IO uint32_t QUADSPI_TypeDef::DLR |
QUADSPI Data Length register, Address offset: 0x10
| __IO uint32_t QUADSPI_TypeDef::DR |
QUADSPI Data register, Address offset: 0x20
| __IO uint32_t QUADSPI_TypeDef::FCR |
QUADSPI Flag Clear register, Address offset: 0x0C
| __IO uint32_t QUADSPI_TypeDef::LPTR |
QUADSPI Low Power Timeout register, Address offset: 0x30
| __IO uint32_t QUADSPI_TypeDef::PIR |
QUADSPI Polling Interval register, Address offset: 0x2C
| __IO uint32_t QUADSPI_TypeDef::PSMAR |
QUADSPI Polling Status Match register, Address offset: 0x28
| __IO uint32_t QUADSPI_TypeDef::PSMKR |
QUADSPI Polling Status Mask register, Address offset: 0x24
| __IO uint32_t QUADSPI_TypeDef::SR |
QUADSPI Status register, Address offset: 0x08
