RTEMS 6.1
PWREx Wakeup pin configuration structure definition. More...
#include <stm32h7xx_hal_pwr_ex.h>
Data Fields | |
| uint32_t | WakeUpPin |
| uint32_t | PinPolarity |
| uint32_t | PinPull |
| uint32_t PWREx_WakeupPinTypeDef::PinPolarity |
PinPolarity: Specifies the Wake-Up pin polarity. This parameter can be a value of PWREx Pin Polarity configuration
| uint32_t PWREx_WakeupPinTypeDef::PinPull |
PinPull: Specifies the Wake-Up pin pull. This parameter can be a value of PWREx Pin Pull configuration
| uint32_t PWREx_WakeupPinTypeDef::WakeUpPin |
WakeUpPin: Specifies the Wake-Up pin to be enabled. This parameter can be a value of PWREx Wake-Up Pins
