RTEMS 6.1
#include <MIMXRT1052.h>
struct {
   __I uint16_t   PWM_Type::CNT
   __IO uint16_t   PWM_Type::INIT
   __IO uint16_t   PWM_Type::CTRL2
   uint8_t   RESERVED_0 [2]
   __IO uint16_t   PWM_Type::VAL0
   __IO uint16_t   PWM_Type::FRACVAL1
   __IO uint16_t   PWM_Type::VAL1
   __IO uint16_t   PWM_Type::FRACVAL2
   __IO uint16_t   PWM_Type::VAL2
   __IO uint16_t   PWM_Type::FRACVAL3
   __IO uint16_t   PWM_Type::VAL3
   __IO uint16_t   PWM_Type::FRACVAL4
   __IO uint16_t   PWM_Type::VAL4
   __IO uint16_t   PWM_Type::FRACVAL5
   __IO uint16_t   PWM_Type::VAL5
   __IO uint16_t   PWM_Type::FRCTRL
   __IO uint16_t   PWM_Type::OCTRL
   __IO uint16_t   PWM_Type::STS
   __IO uint16_t   PWM_Type::INTEN
   __IO uint16_t   PWM_Type::DMAEN
   __IO uint16_t   PWM_Type::TCTRL
   __IO uint16_t   PWM_Type::DISMAP [2]
   __IO uint16_t   PWM_Type::DTCNT0
   __IO uint16_t   PWM_Type::DTCNT1
   __IO uint16_t   PWM_Type::CAPTCTRLA
   __IO uint16_t   PWM_Type::CAPTCOMPA
   __IO uint16_t   PWM_Type::CAPTCTRLB
   __IO uint16_t   PWM_Type::CAPTCOMPB
   __IO uint16_t   PWM_Type::CAPTCTRLX
   __IO uint16_t   PWM_Type::CAPTCOMPX
   __I uint16_t   PWM_Type::CVAL0
   __I uint16_t   PWM_Type::CVAL0CYC
   __I uint16_t   PWM_Type::CVAL1
   __I uint16_t   PWM_Type::CVAL1CYC
   __I uint16_t   PWM_Type::CVAL2
   __I uint16_t   PWM_Type::CVAL2CYC
   __I uint16_t   PWM_Type::CVAL3
   __I uint16_t   PWM_Type::CVAL3CYC
   __I uint16_t   PWM_Type::CVAL4
   __I uint16_t   PWM_Type::CVAL4CYC
   __I uint16_t   PWM_Type::CVAL5
   __I uint16_t   PWM_Type::CVAL5CYC
   uint8_t   RESERVED_1 [8]
SM [4]
__IO uint16_t OUTEN
__IO uint16_t MASK
__IO uint16_t SWCOUT
__IO uint16_t DTSRCSEL
__IO uint16_t MCTRL
__IO uint16_t MCTRL2
__IO uint16_t FCTRL
__IO uint16_t FSTS
__IO uint16_t FFILT
__IO uint16_t FTST
__IO uint16_t FCTRL2
struct {
   __IO uint16_t   PWM_Type::DISMAP [1]
   uint8_t   RESERVED_1 [2]
   uint8_t   RESERVED_2 [8]
SM [4]
struct {
SM [4]
PWM - Register Layout Typedef
The documentation for this struct was generated from the following files:
