RTEMS 6.1
PSSI. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t SR
__IO uint32_t RIS
__IO uint32_t IER
__IO uint32_t MIS
__IO uint32_t ICR
__IO uint32_t RESERVED1 [4]
__IO uint32_t DR
__IO uint32_t RESERVED2 [241]
__IO uint32_t HWCFGR
__IO uint32_t VERR
__IO uint32_t IPIDR
__IO uint32_t SIDR
PSSI.
Field Documentation
◆ CR
__IO uint32_t PSSI_TypeDef::CR
PSSI control register 1, Address offset: 0x000
◆ DR
__IO uint32_t PSSI_TypeDef::DR
PSSI data register, Address offset: 0x028
◆ HWCFGR
__IO uint32_t PSSI_TypeDef::HWCFGR
PSSI IP HW configuration register, Address offset: 0x3F0
◆ ICR
__IO uint32_t PSSI_TypeDef::ICR
PSSI interrupt clear register, Address offset: 0x014
◆ IER
__IO uint32_t PSSI_TypeDef::IER
PSSI interrupt enable register, Address offset: 0x00C
◆ IPIDR
__IO uint32_t PSSI_TypeDef::IPIDR
PSSI IP ID register, Address offset: 0x3F8
◆ MIS
__IO uint32_t PSSI_TypeDef::MIS
PSSI masked interrupt status register, Address offset: 0x010
◆ RESERVED1
__IO uint32_t PSSI_TypeDef::RESERVED1
Reserved, 0x018 - 0x024
◆ RESERVED2
__IO uint32_t PSSI_TypeDef::RESERVED2
Reserved, 0x02C - 0x3EC
◆ RIS
__IO uint32_t PSSI_TypeDef::RIS
PSSI raw interrupt status register, Address offset: 0x008
◆ SIDR
__IO uint32_t PSSI_TypeDef::SIDR
PSSI SIZE ID register, Address offset: 0x3FC
◆ SR
__IO uint32_t PSSI_TypeDef::SR
PSSI status register, Address offset: 0x004
◆ VERR
__IO uint32_t PSSI_TypeDef::VERR
PSSI IP version register, Address offset: 0x3F4
The documentation for this struct was generated from the following files:
