RTEMS 6.1
#include <MIMXRT1166_cm4.h>
struct {
   __IO uint32_t   OSC_RC_400M_Type::RW
   __IO uint32_t   OSC_RC_400M_Type::SET
   __IO uint32_t   OSC_RC_400M_Type::CLR
   __IO uint32_t   OSC_RC_400M_Type::TOG
CTRL0
struct {
CTRL1
struct {
CTRL2
struct {
CTRL3
uint8_t RESERVED_0 [16]
struct {
   __I uint32_t   OSC_RC_400M_Type::RW
   __I uint32_t   OSC_RC_400M_Type::SET
   __I uint32_t   OSC_RC_400M_Type::CLR
   __I uint32_t   OSC_RC_400M_Type::TOG
STAT0
struct {
STAT1
struct {
STAT2
struct {
CTRL0
struct {
CTRL1
struct {
CTRL2
struct {
CTRL3
struct {
STAT0
struct {
STAT1
struct {
STAT2
OSC_RC_400M - Register Layout Typedef
The documentation for this struct was generated from the following files:
