RTEMS 6.1
OPAMP_InitTypeDef Struct Reference
OPAMP Init structure definition
More...
#include <stm32h7xx_hal_opamp.h>
uint32_t PowerMode
uint32_t Mode
uint32_t InvertingInput
uint32_t NonInvertingInput
uint32_t PgaGain
uint32_t PgaConnect
uint32_t UserTrimming
uint32_t TrimmingValueP
uint32_t TrimmingValueN
uint32_t TrimmingValuePHighSpeed
uint32_t TrimmingValueNHighSpeed
Field Documentation
◆ InvertingInput
uint32_t OPAMP_InitTypeDef::InvertingInput
Specifies the inverting input in Standalone & PGA modes
  • In Standalone mode i.e when mode is OPAMP_STANDALONE_MODE This parameter must be a value of OPAMP Inverting Input
  • In Follower mode i.e when mode is OPAMP_FOLLOWER_MODE & In PGA mode i.e when mode is OPAMP_PGA_MODE This parameter is Not Applicable
◆ Mode
uint32_t OPAMP_InitTypeDef::Mode
Specifies the OPAMP mode This parameter must be a value of OPAMP Mode mode is either Standalone, - Follower or PGA
◆ NonInvertingInput
uint32_t OPAMP_InitTypeDef::NonInvertingInput
Specifies the non inverting input of the opamp: This parameter must be a value of OPAMP Non Inverting Input
◆ PgaConnect
uint32_t OPAMP_InitTypeDef::PgaConnect
Specifies the inverting pin in PGA mode i.e. when mode is OPAMP_PGA_MODE This parameter must be a value of OPAMP Pga Connect Either: not connected, connected to VINM0, connected to VINM1 (VINM0 or VINM1 are typically used for external filtering)
◆ PgaGain
uint32_t OPAMP_InitTypeDef::PgaGain
Specifies the gain in PGA mode i.e. when mode is OPAMP_PGA_MODE. This parameter must be a value of OPAMP Pga Gain
◆ PowerMode
uint32_t OPAMP_InitTypeDef::PowerMode
Specifies the power mode Normal or High Speed. This parameter must be a value of OPAMP PowerMode
◆ TrimmingValueN
uint32_t OPAMP_InitTypeDef::TrimmingValueN
Specifies the offset trimming value (NMOS) in Normal Mode i.e. when UserTrimming is OPAMP_TRIMMING_USER. This parameter must be a number between Min_Data = 0 and Max_Data = 31. 16 is typical default value
◆ TrimmingValueNHighSpeed
uint32_t OPAMP_InitTypeDef::TrimmingValueNHighSpeed
Specifies the offset trimming value (NMOS) in High Speed Mode i.e. when UserTrimming is OPAMP_TRIMMING_USER. This parameter must be a number between Min_Data = 0 and Max_Data = 31. 16 is typical default value
◆ TrimmingValueP
uint32_t OPAMP_InitTypeDef::TrimmingValueP
Specifies the offset trimming value (PMOS) in Normal Mode i.e. when UserTrimming is OPAMP_TRIMMING_USER. This parameter must be a number between Min_Data = 0 and Max_Data = 31. 16 is typical default value
◆ TrimmingValuePHighSpeed
uint32_t OPAMP_InitTypeDef::TrimmingValuePHighSpeed
Specifies the offset trimming value (PMOS) in High Speed Mode i.e. when UserTrimming is OPAMP_TRIMMING_USER. This parameter must be a number between Min_Data = 0 and Max_Data = 31. 16 is typical default value
◆ UserTrimming
uint32_t OPAMP_InitTypeDef::UserTrimming
Specifies the trimming mode This parameter must be a value of OPAMP User Trimming UserTrimming is either factory or user trimming.
