RTEMS 6.1
OCTO Serial Peripheral Interface. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | CR |
| uint32_t | RESERVED |
| __IO uint32_t | DCR1 |
| __IO uint32_t | DCR2 |
| __IO uint32_t | DCR3 |
| __IO uint32_t | DCR4 |
| uint32_t | RESERVED1 [2] |
| __IO uint32_t | SR |
| __IO uint32_t | FCR |
| uint32_t | RESERVED2 [6] |
| __IO uint32_t | DLR |
| uint32_t | RESERVED3 |
| __IO uint32_t | AR |
| uint32_t | RESERVED4 |
| __IO uint32_t | DR |
| uint32_t | RESERVED5 [11] |
| __IO uint32_t | PSMKR |
| uint32_t | RESERVED6 |
| __IO uint32_t | PSMAR |
| uint32_t | RESERVED7 |
| __IO uint32_t | PIR |
| uint32_t | RESERVED8 [27] |
| __IO uint32_t | CCR |
| uint32_t | RESERVED9 |
| __IO uint32_t | TCR |
| uint32_t | RESERVED10 |
| __IO uint32_t | IR |
| uint32_t | RESERVED11 [3] |
| __IO uint32_t | ABR |
| uint32_t | RESERVED12 [3] |
| __IO uint32_t | LPTR |
| uint32_t | RESERVED13 [3] |
| __IO uint32_t | WPCCR |
| uint32_t | RESERVED14 |
| __IO uint32_t | WPTCR |
| uint32_t | RESERVED15 |
| __IO uint32_t | WPIR |
| uint32_t | RESERVED16 [3] |
| __IO uint32_t | WPABR |
| uint32_t | RESERVED17 [7] |
| __IO uint32_t | WCCR |
| uint32_t | RESERVED18 |
| __IO uint32_t | WTCR |
| uint32_t | RESERVED19 |
| __IO uint32_t | WIR |
| uint32_t | RESERVED20 [3] |
| __IO uint32_t | WABR |
| uint32_t | RESERVED21 [23] |
| __IO uint32_t | HLCR |
| uint32_t | RESERVED22 [122] |
| __IO uint32_t | HWCFGR |
| __IO uint32_t | VER |
| __IO uint32_t | ID |
| __IO uint32_t | MID |
| __IO uint32_t OCTOSPI_TypeDef::ABR |
OCTOSPI Alternate Bytes register, Address offset: 0x120
| __IO uint32_t OCTOSPI_TypeDef::AR |
OCTOSPI Address register, Address offset: 0x048
| __IO uint32_t OCTOSPI_TypeDef::CCR |
OCTOSPI Communication Configuration register, Address offset: 0x100
| __IO uint32_t OCTOSPI_TypeDef::CR |
OCTOSPI Control register, Address offset: 0x000
| __IO uint32_t OCTOSPI_TypeDef::DCR1 |
OCTOSPI Device Configuration register 1, Address offset: 0x008
| __IO uint32_t OCTOSPI_TypeDef::DCR2 |
OCTOSPI Device Configuration register 2, Address offset: 0x00C
| __IO uint32_t OCTOSPI_TypeDef::DCR3 |
OCTOSPI Device Configuration register 3, Address offset: 0x010
| __IO uint32_t OCTOSPI_TypeDef::DCR4 |
OCTOSPI Device Configuration register 4, Address offset: 0x014
| __IO uint32_t OCTOSPI_TypeDef::DLR |
OCTOSPI Data Length register, Address offset: 0x040
| __IO uint32_t OCTOSPI_TypeDef::DR |
OCTOSPI Data register, Address offset: 0x050
| __IO uint32_t OCTOSPI_TypeDef::FCR |
OCTOSPI Flag Clear register, Address offset: 0x024
| __IO uint32_t OCTOSPI_TypeDef::HLCR |
OCTOSPI Hyperbus Latency Configuration register, Address offset: 0x200
| __IO uint32_t OCTOSPI_TypeDef::HWCFGR |
OCTOSPI HW Configuration register, Address offset: 0x3F0
| __IO uint32_t OCTOSPI_TypeDef::ID |
OCTOSPI Identification register, Address offset: 0x3F8
| __IO uint32_t OCTOSPI_TypeDef::IR |
OCTOSPI Instruction register, Address offset: 0x110
| __IO uint32_t OCTOSPI_TypeDef::LPTR |
OCTOSPI Low Power Timeout register, Address offset: 0x130
| __IO uint32_t OCTOSPI_TypeDef::MID |
OCTOPSI HW Magic ID register, Address offset: 0x3FC
| __IO uint32_t OCTOSPI_TypeDef::PIR |
OCTOSPI Polling Interval register, Address offset: 0x090
| __IO uint32_t OCTOSPI_TypeDef::PSMAR |
OCTOSPI Polling Status Match register, Address offset: 0x088
| __IO uint32_t OCTOSPI_TypeDef::PSMKR |
OCTOSPI Polling Status Mask register, Address offset: 0x080
| uint32_t OCTOSPI_TypeDef::RESERVED |
Reserved, Address offset: 0x004
| uint32_t OCTOSPI_TypeDef::RESERVED1 |
Reserved, Address offset: 0x018-0x01C
| uint32_t OCTOSPI_TypeDef::RESERVED10 |
Reserved, Address offset: 0x10C
| uint32_t OCTOSPI_TypeDef::RESERVED11 |
Reserved, Address offset: 0x114-0x11C
| uint32_t OCTOSPI_TypeDef::RESERVED12 |
Reserved, Address offset: 0x124-0x12C
| uint32_t OCTOSPI_TypeDef::RESERVED13 |
Reserved, Address offset: 0x134-0x13C
| uint32_t OCTOSPI_TypeDef::RESERVED14 |
Reserved, Address offset: 0x144
| uint32_t OCTOSPI_TypeDef::RESERVED15 |
Reserved, Address offset: 0x14C
| uint32_t OCTOSPI_TypeDef::RESERVED16 |
Reserved, Address offset: 0x154-0x15C
| uint32_t OCTOSPI_TypeDef::RESERVED17 |
Reserved, Address offset: 0x164-0x17C
| uint32_t OCTOSPI_TypeDef::RESERVED18 |
Reserved, Address offset: 0x184
| uint32_t OCTOSPI_TypeDef::RESERVED19 |
Reserved, Address offset: 0x18C
| uint32_t OCTOSPI_TypeDef::RESERVED2 |
Reserved, Address offset: 0x028-0x03C
| uint32_t OCTOSPI_TypeDef::RESERVED20 |
Reserved, Address offset: 0x194-0x19C
| uint32_t OCTOSPI_TypeDef::RESERVED21 |
Reserved, Address offset: 0x1A4-0x1FC
| uint32_t OCTOSPI_TypeDef::RESERVED22 |
Reserved, Address offset: 0x204-0x3EC
| uint32_t OCTOSPI_TypeDef::RESERVED3 |
Reserved, Address offset: 0x044
| uint32_t OCTOSPI_TypeDef::RESERVED4 |
Reserved, Address offset: 0x04C
| uint32_t OCTOSPI_TypeDef::RESERVED5 |
Reserved, Address offset: 0x054-0x07C
| uint32_t OCTOSPI_TypeDef::RESERVED6 |
Reserved, Address offset: 0x084
| uint32_t OCTOSPI_TypeDef::RESERVED7 |
Reserved, Address offset: 0x08C
| uint32_t OCTOSPI_TypeDef::RESERVED8 |
Reserved, Address offset: 0x094-0x0FC
| uint32_t OCTOSPI_TypeDef::RESERVED9 |
Reserved, Address offset: 0x104
| __IO uint32_t OCTOSPI_TypeDef::SR |
OCTOSPI Status register, Address offset: 0x020
| __IO uint32_t OCTOSPI_TypeDef::TCR |
OCTOSPI Timing Configuration register, Address offset: 0x108
| __IO uint32_t OCTOSPI_TypeDef::VER |
OCTOSPI Version register, Address offset: 0x3F4
| __IO uint32_t OCTOSPI_TypeDef::WABR |
OCTOSPI Write Alternate Bytes register, Address offset: 0x1A0
| __IO uint32_t OCTOSPI_TypeDef::WCCR |
OCTOSPI Write Communication Configuration register, Address offset: 0x180
| __IO uint32_t OCTOSPI_TypeDef::WIR |
OCTOSPI Write Instruction register, Address offset: 0x190
| __IO uint32_t OCTOSPI_TypeDef::WPABR |
OCTOSPI Wrap Alternate Bytes register, Address offset: 0x160
| __IO uint32_t OCTOSPI_TypeDef::WPCCR |
OCTOSPI Wrap Communication Configuration register, Address offset: 0x140
| __IO uint32_t OCTOSPI_TypeDef::WPIR |
OCTOSPI Wrap Instruction register, Address offset: 0x150
| __IO uint32_t OCTOSPI_TypeDef::WPTCR |
OCTOSPI Wrap Timing Configuration register, Address offset: 0x148
| __IO uint32_t OCTOSPI_TypeDef::WTCR |
OCTOSPI Write Timing Configuration register, Address offset: 0x188
