RTEMS 6.1
#include <MIMXRT1052.h>
Data Fields | |
| __IO uint32_t | CTRL |
| __IO uint32_t | CTRL_SET |
| __IO uint32_t | CTRL_CLR |
| __IO uint32_t | CTRL_TOG |
| __IO uint32_t | TIMING |
| uint8_t | RESERVED_0 [12] |
| __IO uint32_t | DATA |
| uint8_t | RESERVED_1 [12] |
| __IO uint32_t | READ_CTRL |
| uint8_t | RESERVED_2 [12] |
| __IO uint32_t | READ_FUSE_DATA |
| uint8_t | RESERVED_3 [12] |
| __IO uint32_t | SW_STICKY |
| uint8_t | RESERVED_4 [12] |
| __IO uint32_t | SCS |
| __IO uint32_t | SCS_SET |
| __IO uint32_t | SCS_CLR |
| __IO uint32_t | SCS_TOG |
| uint8_t | RESERVED_5 [32] |
| __I uint32_t | VERSION |
| uint8_t | RESERVED_6 [108] |
| __IO uint32_t | TIMING2 |
| uint8_t | RESERVED_7 [764] |
| __IO uint32_t | LOCK |
| uint8_t | RESERVED_8 [12] |
| __IO uint32_t | CFG0 |
| uint8_t | RESERVED_9 [12] |
| __IO uint32_t | CFG1 |
| uint8_t | RESERVED_10 [12] |
| __IO uint32_t | CFG2 |
| uint8_t | RESERVED_11 [12] |
| __IO uint32_t | CFG3 |
| uint8_t | RESERVED_12 [12] |
| __IO uint32_t | CFG4 |
| uint8_t | RESERVED_13 [12] |
| __IO uint32_t | CFG5 |
| uint8_t | RESERVED_14 [12] |
| __IO uint32_t | CFG6 |
| uint8_t | RESERVED_15 [12] |
| __IO uint32_t | MEM0 |
| uint8_t | RESERVED_16 [12] |
| __IO uint32_t | MEM1 |
| uint8_t | RESERVED_17 [12] |
| __IO uint32_t | MEM2 |
| uint8_t | RESERVED_18 [12] |
| __IO uint32_t | MEM3 |
| uint8_t | RESERVED_19 [12] |
| __IO uint32_t | MEM4 |
| uint8_t | RESERVED_20 [12] |
| __IO uint32_t | ANA0 |
| uint8_t | RESERVED_21 [12] |
| __IO uint32_t | ANA1 |
| uint8_t | RESERVED_22 [12] |
| __IO uint32_t | ANA2 |
| uint8_t | RESERVED_23 [140] |
| __IO uint32_t | SRK0 |
| uint8_t | RESERVED_24 [12] |
| __IO uint32_t | SRK1 |
| uint8_t | RESERVED_25 [12] |
| __IO uint32_t | SRK2 |
| uint8_t | RESERVED_26 [12] |
| __IO uint32_t | SRK3 |
| uint8_t | RESERVED_27 [12] |
| __IO uint32_t | SRK4 |
| uint8_t | RESERVED_28 [12] |
| __IO uint32_t | SRK5 |
| uint8_t | RESERVED_29 [12] |
| __IO uint32_t | SRK6 |
| uint8_t | RESERVED_30 [12] |
| __IO uint32_t | SRK7 |
| uint8_t | RESERVED_31 [12] |
| __IO uint32_t | SJC_RESP0 |
| uint8_t | RESERVED_32 [12] |
| __IO uint32_t | SJC_RESP1 |
| uint8_t | RESERVED_33 [12] |
| __IO uint32_t | MAC0 |
| uint8_t | RESERVED_34 [12] |
| __IO uint32_t | MAC1 |
| uint8_t | RESERVED_35 [12] |
| __IO uint32_t | GP3 |
| uint8_t | RESERVED_36 [28] |
| __IO uint32_t | GP1 |
| uint8_t | RESERVED_37 [12] |
| __IO uint32_t | GP2 |
| uint8_t | RESERVED_38 [12] |
| __IO uint32_t | SW_GP1 |
| uint8_t | RESERVED_39 [12] |
| __IO uint32_t | SW_GP20 |
| uint8_t | RESERVED_40 [12] |
| __IO uint32_t | SW_GP21 |
| uint8_t | RESERVED_41 [12] |
| __IO uint32_t | SW_GP22 |
| uint8_t | RESERVED_42 [12] |
| __IO uint32_t | SW_GP23 |
| uint8_t | RESERVED_43 [12] |
| __IO uint32_t | MISC_CONF0 |
| uint8_t | RESERVED_44 [12] |
| __IO uint32_t | MISC_CONF1 |
| uint8_t | RESERVED_45 [12] |
| __IO uint32_t | SRK_REVOKE |
| __IO uint32_t | PDN |
| __IO uint32_t | OUT_STATUS |
| __IO uint32_t | OUT_STATUS_SET |
| __IO uint32_t | OUT_STATUS_CLR |
| __IO uint32_t | OUT_STATUS_TOG |
| struct { | |
| __IO uint32_t OCOTP_Type::READ_FUSE_DATA | |
| uint8_t RESERVED_0 [12] | |
| } | READ_FUSE_DATAS [4] |
| __IO uint32_t | SW_LOCK |
| __IO uint32_t | BIT_LOCK |
| __I uint32_t | LOCKED0 |
| __I uint32_t | LOCKED1 |
| __I uint32_t | LOCKED2 |
| __I uint32_t | LOCKED3 |
| __I uint32_t | LOCKED4 |
| struct { | |
| __I uint32_t OCOTP_Type::FUSE | |
| } | FUSEN [144] |
| struct { | |
| struct { | |
| } | FUSEN [144] |
OCOTP - Register Layout Typedef
