RTEMS 6.1
FMC NOR ID typedef. More...
#include <stm32h7xx_hal_nor.h>
Data Fields | |
| uint16_t | Manufacturer_Code |
| uint16_t | Device_Code1 |
| uint16_t | Device_Code2 |
| uint16_t | Device_Code3 |
FMC NOR ID typedef.
| uint16_t NOR_IDTypeDef::Device_Code3 |
Defines the device's codes used to identify the memory. These codes can be accessed by performing read operations with specific control signals and addresses set.They can also be accessed by issuing an Auto Select command
| uint16_t NOR_IDTypeDef::Manufacturer_Code |
Defines the device's manufacturer code used to identify the memory
