RTEMS 6.1
#include <MIMXRT1166_cm4.h>
Data Fields | |
| uint8_t | RESERVED_0 [256] |
| __IO uint32_t | CFG_NUM_LANES |
| __IO uint32_t | CFG_DISABLE_DATA_LANES |
| __I uint32_t | BIT_ERR |
| __I uint32_t | IRQ_STATUS |
| __IO uint32_t | IRQ_MASK |
| __I uint32_t | ULPS_STATUS |
| __I uint32_t | PPI_ERRSOT_HS |
| __I uint32_t | PPI_ERRSOTSYNC_HS |
| __I uint32_t | PPI_ERRESC |
| __I uint32_t | PPI_ERRSYNCESC |
| __I uint32_t | PPI_ERRCONTROL |
| __IO uint32_t | CFG_DISABLE_PAYLOAD_0 |
| __IO uint32_t | CFG_DISABLE_PAYLOAD_1 |
| uint8_t | RESERVED_1 [76] |
| __IO uint32_t | CFG_IGNORE_VC |
| __IO uint32_t | CFG_VID_VC |
| __IO uint32_t | CFG_VID_P_FIFO_SEND_LEVEL |
| __IO uint32_t | CFG_VID_VSYNC |
| __IO uint32_t | CFG_VID_HSYNC_FP |
| __IO uint32_t | CFG_VID_HSYNC |
| __IO uint32_t | CFG_VID_HSYNC_BP |
MIPI_CSI2RX - Register Layout Typedef
