RTEMS
6.1
MECC_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
MECC Peripheral Access Layer
MIMXRT1166_cm4.h
__IO
uint32_t
ERR_STATUS
__IO
uint32_t
ERR_STAT_EN
__IO
uint32_t
ERR_SIG_EN
__IO
uint32_t
ERR_DATA_INJ_LOW0
__IO
uint32_t
ERR_DATA_INJ_HIGH0
__IO
uint32_t
ERR_ECC_INJ0
__IO
uint32_t
ERR_DATA_INJ_LOW1
__IO
uint32_t
ERR_DATA_INJ_HIGH1
__IO
uint32_t
ERR_ECC_INJ1
__IO
uint32_t
ERR_DATA_INJ_LOW2
__IO
uint32_t
ERR_DATA_INJ_HIGH2
__IO
uint32_t
ERR_ECC_INJ2
__IO
uint32_t
ERR_DATA_INJ_LOW3
__IO
uint32_t
ERR_DATA_INJ_HIGH3
__IO
uint32_t
ERR_ECC_INJ3
__I
uint32_t
SINGLE_ERR_ADDR_ECC0
__I
uint32_t
SINGLE_ERR_DATA_LOW0
__I
uint32_t
SINGLE_ERR_DATA_HIGH0
__I
uint32_t
SINGLE_ERR_POS_LOW0
__I
uint32_t
SINGLE_ERR_POS_HIGH0
__I
uint32_t
SINGLE_ERR_ADDR_ECC1
__I
uint32_t
SINGLE_ERR_DATA_LOW1
__I
uint32_t
SINGLE_ERR_DATA_HIGH1
__I
uint32_t
SINGLE_ERR_POS_LOW1
__I
uint32_t
SINGLE_ERR_POS_HIGH1
__I
uint32_t
SINGLE_ERR_ADDR_ECC2
__I
uint32_t
SINGLE_ERR_DATA_LOW2
__I
uint32_t
SINGLE_ERR_DATA_HIGH2
__I
uint32_t
SINGLE_ERR_POS_LOW2
__I
uint32_t
SINGLE_ERR_POS_HIGH2
__I
uint32_t
SINGLE_ERR_ADDR_ECC3
__I
uint32_t
SINGLE_ERR_DATA_LOW3
__I
uint32_t
SINGLE_ERR_DATA_HIGH3
__I
uint32_t
SINGLE_ERR_POS_LOW3
__I
uint32_t
SINGLE_ERR_POS_HIGH3
__I
uint32_t
MULTI_ERR_ADDR_ECC0
__I
uint32_t
MULTI_ERR_DATA_LOW0
__I
uint32_t
MULTI_ERR_DATA_HIGH0
__I
uint32_t
MULTI_ERR_ADDR_ECC1
__I
uint32_t
MULTI_ERR_DATA_LOW1
__I
uint32_t
MULTI_ERR_DATA_HIGH1
__I
uint32_t
MULTI_ERR_ADDR_ECC2
__I
uint32_t
MULTI_ERR_DATA_LOW2
__I
uint32_t
MULTI_ERR_DATA_HIGH2
__I
uint32_t
MULTI_ERR_ADDR_ECC3
__I
uint32_t
MULTI_ERR_DATA_LOW3
__I
uint32_t
MULTI_ERR_DATA_HIGH3
uint8_t
RESERVED_0
[68]
__IO
uint32_t
PIPE_ECC_EN
__I
uint32_t
PENDING_STAT
MECC - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
