RTEMS 6.1
MDMA_LinkNodeTypeDef Struct Reference
HAL MDMA linked list node structure definition. More...
#include <stm32h7xx_hal_mdma.h>
__IO uint32_t CTCR
__IO uint32_t CBNDTR
__IO uint32_t CSAR
__IO uint32_t CDAR
__IO uint32_t CBRUR
__IO uint32_t CLAR
__IO uint32_t CTBR
__IO uint32_t Reserved
__IO uint32_t CMAR
__IO uint32_t CMDR
Note
The Linked list node allows to define a new MDMA configuration (CTCR ,CBNDTR ,CSAR ,CDAR ,CBRUR, CLAR, CTBR, CMAR and CMDR registers). When CLAR register is configured to a non NULL value , each time a transfer ends, a new configuration (linked list node) is automatically loaded from the address given in CLAR register.
Field Documentation
◆ CBNDTR
__IO uint32_t MDMA_LinkNodeTypeDef::CBNDTR
New CBNDTR register configuration for the given MDMA linked list node
◆ CBRUR
__IO uint32_t MDMA_LinkNodeTypeDef::CBRUR
New CBRUR register configuration for the given MDMA linked list node
◆ CDAR
__IO uint32_t MDMA_LinkNodeTypeDef::CDAR
New CDAR register configuration for the given MDMA linked list node
◆ CLAR
__IO uint32_t MDMA_LinkNodeTypeDef::CLAR
New CLAR register configuration for the given MDMA linked list node
◆ CMAR
__IO uint32_t MDMA_LinkNodeTypeDef::CMAR
New CMAR register configuration for the given MDMA linked list node
◆ CMDR
__IO uint32_t MDMA_LinkNodeTypeDef::CMDR
New CMDR register configuration for the given MDMA linked list node
◆ CSAR
__IO uint32_t MDMA_LinkNodeTypeDef::CSAR
New CSAR register configuration for the given MDMA linked list node
◆ CTBR
__IO uint32_t MDMA_LinkNodeTypeDef::CTBR
New CTBR register configuration for the given MDMA linked list node
◆ CTCR
__IO uint32_t MDMA_LinkNodeTypeDef::CTCR
New CTCR register configuration for the given MDMA linked list node
◆ Reserved
__IO uint32_t MDMA_LinkNodeTypeDef::Reserved
Reserved register
