RTEMS 6.1
MDMA_InitTypeDef Struct Reference
MDMA Configuration Structure definition. More...
#include <stm32h7xx_hal_mdma.h>
uint32_t Request
uint32_t TransferTriggerMode
uint32_t Priority
uint32_t Endianness
uint32_t SourceInc
uint32_t DestinationInc
uint32_t SourceDataSize
uint32_t DestDataSize
uint32_t DataAlignment
uint32_t BufferTransferLength
uint32_t SourceBurst
uint32_t DestBurst
int32_t SourceBlockAddressOffset
int32_t DestBlockAddressOffset
Field Documentation
◆ BufferTransferLength
uint32_t MDMA_InitTypeDef::BufferTransferLength
Specifies the buffer Transfer Length (number of bytes), this is the number of bytes to be transferred in a single transfer (1 byte to 128 bytes)
◆ DataAlignment
uint32_t MDMA_InitTypeDef::DataAlignment
Specifies the source to destination Memory data packing/padding mode. This parameter can be a value of MDMA data alignment
◆ DestBlockAddressOffset
int32_t MDMA_InitTypeDef::DestBlockAddressOffset
this field specifies the Next block destination address offset signed value : if > 0 then increment the next block destination Address by offset from where the last block ends if < 0 then decrement the next block destination Address by offset from where the last block ends if == 0, the next block destination address starts from where the last block ends
◆ DestBurst
uint32_t MDMA_InitTypeDef::DestBurst
Specifies the Burst transfer configuration for the destination memory transfers. It specifies the amount of data to be transferred in a single non interruptible transaction. This parameter can be a value of MDMA Destination burst
Note
: the burst may be FIXED/INCR based on DestinationInc value , the BURST must be programmed as to ensure that the burst size will be lower than than BufferTransferLength
◆ DestDataSize
uint32_t MDMA_InitTypeDef::DestDataSize
Specifies the destination data size. This parameter can be a value of MDMA Destination data size
◆ DestinationInc
uint32_t MDMA_InitTypeDef::DestinationInc
Specifies if the Destination increment mode . This parameter can be a value of MDMA Destination increment mode
◆ Endianness
uint32_t MDMA_InitTypeDef::Endianness
Specifies if the MDMA transactions preserve the Little endianness. This parameter can be a value of MDMA Endianness
◆ Priority
uint32_t MDMA_InitTypeDef::Priority
Specifies the software priority for the MDMAy channelx. This parameter can be a value of MDMA Priority level
◆ Request
uint32_t MDMA_InitTypeDef::Request
Specifies the MDMA request. This parameter can be a value of MDMA Request selection
◆ SourceBlockAddressOffset
int32_t MDMA_InitTypeDef::SourceBlockAddressOffset
this field specifies the Next block source address offset signed value : if > 0 then increment the next block source Address by offset from where the last block ends if < 0 then decrement the next block source Address by offset from where the last block ends if == 0, the next block source address starts from where the last block ends
◆ SourceBurst
uint32_t MDMA_InitTypeDef::SourceBurst
Specifies the Burst transfer configuration for the source memory transfers. It specifies the amount of data to be transferred in a single non interruptible transaction. This parameter can be a value of MDMA Source burst
Note
: the burst may be FIXED/INCR based on SourceInc value , the BURST must be programmed as to ensure that the burst size will be lower than than BufferTransferLength
◆ SourceDataSize
uint32_t MDMA_InitTypeDef::SourceDataSize
Specifies the source data size. This parameter can be a value of MDMA Source data size
◆ SourceInc
uint32_t MDMA_InitTypeDef::SourceInc
Specifies if the Source increment mode . This parameter can be a value of MDMA Source increment mode
◆ TransferTriggerMode
uint32_t MDMA_InitTypeDef::TransferTriggerMode
Specifies the Trigger Transfer mode : each request triggers a : a buffer transfer, a block transfer, a repeated block transfer or a linked list transfer This parameter can be a value of MDMA Transfer Trigger Mode
