RTEMS 6.1
__IO uint32_t CISR
__IO uint32_t CIFCR
__IO uint32_t CESR
__IO uint32_t CCR
__IO uint32_t CTCR
__IO uint32_t CBNDTR
__IO uint32_t CSAR
__IO uint32_t CDAR
__IO uint32_t CBRUR
__IO uint32_t CLAR
__IO uint32_t CTBR
uint32_t RESERVED0
__IO uint32_t CMAR
__IO uint32_t CMDR
Field Documentation
◆ CBNDTR
__IO uint32_t MDMA_Channel_TypeDef::CBNDTR
MDMA Channel x block number of data register, Address offset: 0x54
◆ CBRUR
__IO uint32_t MDMA_Channel_TypeDef::CBRUR
MDMA channel x Block Repeat address Update register, Address offset: 0x60
◆ CCR
__IO uint32_t MDMA_Channel_TypeDef::CCR
MDMA channel x control register, Address offset: 0x4C
◆ CDAR
__IO uint32_t MDMA_Channel_TypeDef::CDAR
MDMA channel x destination address register, Address offset: 0x5C
◆ CESR
__IO uint32_t MDMA_Channel_TypeDef::CESR
MDMA Channel x error status register, Address offset: 0x48
◆ CIFCR
__IO uint32_t MDMA_Channel_TypeDef::CIFCR
MDMA channel x interrupt flag clear register, Address offset: 0x44
◆ CISR
__IO uint32_t MDMA_Channel_TypeDef::CISR
MDMA channel x interrupt/status register, Address offset: 0x40
◆ CLAR
__IO uint32_t MDMA_Channel_TypeDef::CLAR
MDMA channel x Link Address register, Address offset: 0x64
◆ CMAR
__IO uint32_t MDMA_Channel_TypeDef::CMAR
MDMA channel x Mask address register, Address offset: 0x70
◆ CMDR
__IO uint32_t MDMA_Channel_TypeDef::CMDR
MDMA channel x Mask Data register, Address offset: 0x74
◆ CSAR
__IO uint32_t MDMA_Channel_TypeDef::CSAR
MDMA channel x source address register, Address offset: 0x58
◆ CTBR
__IO uint32_t MDMA_Channel_TypeDef::CTBR
MDMA channel x Trigger and Bus selection Register, Address offset: 0x68
◆ CTCR
__IO uint32_t MDMA_Channel_TypeDef::CTCR
MDMA channel x Transfer Configuration register, Address offset: 0x50
◆ RESERVED0
uint32_t MDMA_Channel_TypeDef::RESERVED0
Reserved, 0x6C
The documentation for this struct was generated from the following files:
