RTEMS 6.1
LCD-TFT Display Controller. More...
#include <stm32h723xx.h>
Data Fields | |
| uint32_t | RESERVED0 [2] |
| __IO uint32_t | SSCR |
| __IO uint32_t | BPCR |
| __IO uint32_t | AWCR |
| __IO uint32_t | TWCR |
| __IO uint32_t | GCR |
| uint32_t | RESERVED1 [2] |
| __IO uint32_t | SRCR |
| uint32_t | RESERVED2 [1] |
| __IO uint32_t | BCCR |
| uint32_t | RESERVED3 [1] |
| __IO uint32_t | IER |
| __IO uint32_t | ISR |
| __IO uint32_t | ICR |
| __IO uint32_t | LIPCR |
| __IO uint32_t | CPSR |
| __IO uint32_t | CDSR |
| __IO uint32_t LTDC_TypeDef::AWCR |
LTDC Active Width Configuration Register, Address offset: 0x10
| __IO uint32_t LTDC_TypeDef::BCCR |
LTDC Background Color Configuration Register, Address offset: 0x2C
| __IO uint32_t LTDC_TypeDef::BPCR |
LTDC Back Porch Configuration Register, Address offset: 0x0C
| __IO uint32_t LTDC_TypeDef::CDSR |
LTDC Current Display Status Register, Address offset: 0x48
| __IO uint32_t LTDC_TypeDef::CPSR |
LTDC Current Position Status Register, Address offset: 0x44
| __IO uint32_t LTDC_TypeDef::GCR |
LTDC Global Control Register, Address offset: 0x18
| __IO uint32_t LTDC_TypeDef::ICR |
LTDC Interrupt Clear Register, Address offset: 0x3C
| __IO uint32_t LTDC_TypeDef::IER |
LTDC Interrupt Enable Register, Address offset: 0x34
| __IO uint32_t LTDC_TypeDef::ISR |
LTDC Interrupt Status Register, Address offset: 0x38
| __IO uint32_t LTDC_TypeDef::LIPCR |
LTDC Line Interrupt Position Configuration Register, Address offset: 0x40
| uint32_t LTDC_TypeDef::RESERVED0 |
Reserved, 0x00-0x04
| uint32_t LTDC_TypeDef::RESERVED1 |
Reserved, 0x1C-0x20
| uint32_t LTDC_TypeDef::RESERVED2 |
Reserved, 0x28
| uint32_t LTDC_TypeDef::RESERVED3 |
Reserved, 0x30
| __IO uint32_t LTDC_TypeDef::SRCR |
LTDC Shadow Reload Configuration Register, Address offset: 0x24
| __IO uint32_t LTDC_TypeDef::SSCR |
LTDC Synchronization Size Configuration Register, Address offset: 0x08
| __IO uint32_t LTDC_TypeDef::TWCR |
LTDC Total Width Configuration Register, Address offset: 0x14
