RTEMS 6.1
LPTIMIMER. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | ISR |
| __IO uint32_t | ICR |
| __IO uint32_t | IER |
| __IO uint32_t | CFGR |
| __IO uint32_t | CR |
| __IO uint32_t | CMP |
| __IO uint32_t | ARR |
| __IO uint32_t | CNT |
| uint32_t | RESERVED1 |
| __IO uint32_t | CFGR2 |
LPTIMIMER.
| __IO uint32_t LPTIM_TypeDef::ARR |
LPTIM Autoreload register, Address offset: 0x18
| __IO uint32_t LPTIM_TypeDef::CFGR |
LPTIM Configuration register, Address offset: 0x0C
| __IO uint32_t LPTIM_TypeDef::CFGR2 |
LPTIM Configuration register, Address offset: 0x24
| __IO uint32_t LPTIM_TypeDef::CMP |
LPTIM Compare register, Address offset: 0x14
| __IO uint32_t LPTIM_TypeDef::CNT |
LPTIM Counter register, Address offset: 0x1C
| __IO uint32_t LPTIM_TypeDef::CR |
LPTIM Control register, Address offset: 0x10
| __IO uint32_t LPTIM_TypeDef::ICR |
LPTIM Interrupt Clear register, Address offset: 0x04
| __IO uint32_t LPTIM_TypeDef::IER |
LPTIM Interrupt Enable register, Address offset: 0x08
| __IO uint32_t LPTIM_TypeDef::ISR |
LPTIM Interrupt and Status register, Address offset: 0x00
| uint32_t LPTIM_TypeDef::RESERVED1 |
Reserved, 0x20
