RTEMS 6.1
#include <MIMXRT1052.h>
__IO uint32_t CTRL
__IO uint32_t CTRL_SET
__IO uint32_t CTRL_CLR
__IO uint32_t CTRL_TOG
__IO uint32_t CTRL1
__IO uint32_t CTRL1_SET
__IO uint32_t CTRL1_CLR
__IO uint32_t CTRL1_TOG
__IO uint32_t CTRL2
__IO uint32_t CTRL2_SET
__IO uint32_t CTRL2_CLR
__IO uint32_t CTRL2_TOG
__IO uint32_t TRANSFER_COUNT
uint8_t RESERVED_0 [12]
__IO uint32_t CUR_BUF
uint8_t RESERVED_1 [12]
__IO uint32_t NEXT_BUF
uint8_t RESERVED_2 [28]
__IO uint32_t VDCTRL0
__IO uint32_t VDCTRL0_SET
__IO uint32_t VDCTRL0_CLR
__IO uint32_t VDCTRL0_TOG
__IO uint32_t VDCTRL1
uint8_t RESERVED_3 [12]
__IO uint32_t VDCTRL2
uint8_t RESERVED_4 [12]
__IO uint32_t VDCTRL3
uint8_t RESERVED_5 [12]
__IO uint32_t VDCTRL4
uint8_t RESERVED_6 [220]
__IO uint32_t BM_ERROR_STAT
uint8_t RESERVED_7 [12]
__IO uint32_t CRC_STAT
uint8_t RESERVED_8 [12]
__I uint32_t STAT
uint8_t RESERVED_9 [236]
__IO uint32_t RGB_ADJUST
__IO uint32_t RGB_ADJUST_SET
__IO uint32_t RGB_ADJUST_CLR
__IO uint32_t RGB_ADJUST_TOG
uint8_t RESERVED_10 [208]
__IO uint32_t PIGEONCTRL0
__IO uint32_t PIGEONCTRL0_SET
__IO uint32_t PIGEONCTRL0_CLR
__IO uint32_t PIGEONCTRL0_TOG
__IO uint32_t PIGEONCTRL1
__IO uint32_t PIGEONCTRL1_SET
__IO uint32_t PIGEONCTRL1_CLR
__IO uint32_t PIGEONCTRL1_TOG
__IO uint32_t PIGEONCTRL2
__IO uint32_t PIGEONCTRL2_SET
__IO uint32_t PIGEONCTRL2_CLR
__IO uint32_t PIGEONCTRL2_TOG
uint8_t RESERVED_11 [1104]
struct {
   __IO uint32_t   LCDIF_Type::PIGEON_0
   __IO uint32_t   LCDIF_Type::PIGEON_1
   __IO uint32_t   LCDIF_Type::PIGEON_2
PIGEON [12]
__IO uint32_t LUT_CTRL
uint8_t RESERVED_12 [12]
__IO uint32_t LUT0_ADDR
uint8_t RESERVED_13 [12]
__IO uint32_t LUT0_DATA
uint8_t RESERVED_14 [12]
__IO uint32_t LUT1_ADDR
uint8_t RESERVED_15 [12]
__IO uint32_t LUT1_DATA
__IO uint32_t THRES
struct {
PIGEON [12]
struct {
PIGEON [12]
LCDIF - Register Layout Typedef
The documentation for this struct was generated from the following files:
