RTEMS 6.1
#include <MIMXRT1166_cm4.h>
__IO uint32_t CTRL
__IO uint32_t CTRL_SET
__IO uint32_t CTRL_CLR
__IO uint32_t CTRL_TOG
__IO uint32_t DISP_PARA
__IO uint32_t DISP_SIZE
__IO uint32_t HSYN_PARA
__IO uint32_t VSYN_PARA
struct {
   __IO uint32_t   LCDIFV2_Type::INT_STATUS
   __IO uint32_t   LCDIFV2_Type::INT_ENABLE
   uint8_t   RESERVED_0 [8]
INT [2]
__IO uint32_t PDI_PARA
struct {
   __IO uint32_t   LCDIFV2_Type::CTRLDESCL1
   __IO uint32_t   LCDIFV2_Type::CTRLDESCL2
   __IO uint32_t   LCDIFV2_Type::CTRLDESCL3
   __IO uint32_t   LCDIFV2_Type::CTRLDESCL4
   __IO uint32_t   LCDIFV2_Type::CTRLDESCL5
   __IO uint32_t   LCDIFV2_Type::CTRLDESCL6
   __IO uint32_t   LCDIFV2_Type::CSC_COEF0
   __IO uint32_t   LCDIFV2_Type::CSC_COEF1
   __IO uint32_t   LCDIFV2_Type::CSC_COEF2
   uint8_t   RESERVED_0 [28]
LAYER [8]
__IO uint32_t CLUT_LOAD
struct {
INT [2]
struct {
LAYER [8]
LCDIFV2 - Register Layout Typedef
The documentation for this struct was generated from the following files:
