RTEMS
6.1
IOMUXC_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
IOMUXC Peripheral Access Layer
MIMXRT1052.h
uint8_t
RESERVED_0
[20]
__IO
uint32_t
SW_MUX_CTL_PAD
[124]
__IO
uint32_t
SW_PAD_CTL_PAD
[124]
__IO
uint32_t
SELECT_INPUT
[154]
IOMUXC - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/
MIMXRT1052.h
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
