RTEMS
6.1
IOMUXC_LPSR_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
IOMUXC_LPSR Peripheral Access Layer
MIMXRT1166_cm4.h
__IO
uint32_t
SW_MUX_CTL_PAD
[16]
__IO
uint32_t
SW_PAD_CTL_PAD
[16]
__IO
uint32_t
SELECT_INPUT
[24]
IOMUXC_LPSR - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
