RTEMS 6.1
HW Semaphore HSEM. More...
#include <stm32h723xx.h>
__IO uint32_t R [32]
__IO uint32_t RLR [32]
__IO uint32_t C1IER
__IO uint32_t C1ICR
__IO uint32_t C1ISR
__IO uint32_t C1MISR
uint32_t Reserved [12]
__IO uint32_t CR
__IO uint32_t KEYR
__IO uint32_t C2IER
__IO uint32_t C2ICR
__IO uint32_t C2ISR
__IO uint32_t C2MISR
HW Semaphore HSEM.
Field Documentation
◆ C1ICR
__IO uint32_t HSEM_TypeDef::C1ICR
HSEM Interrupt clear register , Address offset: 104h
HSEM Interrupt 0 clear register , Address offset: 104h
◆ C1IER
__IO uint32_t HSEM_TypeDef::C1IER
HSEM Interrupt enable register , Address offset: 100h
HSEM Interrupt 0 enable register , Address offset: 100h
◆ C1ISR
__IO uint32_t HSEM_TypeDef::C1ISR
HSEM Interrupt Status register , Address offset: 108h
HSEM Interrupt 0 Status register , Address offset: 108h
◆ C1MISR
__IO uint32_t HSEM_TypeDef::C1MISR
HSEM Interrupt Masked Status register , Address offset: 10Ch
HSEM Interrupt 0 Masked Status register , Address offset: 10Ch
◆ C2ICR
__IO uint32_t HSEM_TypeDef::C2ICR
HSEM Interrupt 1 clear register , Address offset: 114h
◆ C2IER
__IO uint32_t HSEM_TypeDef::C2IER
HSEM Interrupt 1 enable register , Address offset: 110h
◆ C2ISR
__IO uint32_t HSEM_TypeDef::C2ISR
HSEM Interrupt 1 Status register , Address offset: 118h
◆ C2MISR
__IO uint32_t HSEM_TypeDef::C2MISR
HSEM Interrupt 1 Masked Status register , Address offset: 11Ch
◆ CR
__IO uint32_t HSEM_TypeDef::CR
HSEM Semaphore clear register , Address offset: 140h
◆ KEYR
__IO uint32_t HSEM_TypeDef::KEYR
HSEM Semaphore clear key register , Address offset: 144h
◆ R
__IO uint32_t HSEM_TypeDef::R
2-step write lock and read back registers, Address offset: 00h-7Ch
◆ RLR
__IO uint32_t HSEM_TypeDef::RLR
1-step read lock registers, Address offset: 80h-FCh
The documentation for this struct was generated from the following files:
