RTEMS 6.1
__IO uint32_t IER
__IO uint32_t ICR
__IO uint32_t ISR
__IO uint32_t MISR
Field Documentation
◆ ICR
__IO uint32_t HSEM_Common_TypeDef::ICR
HSEM interrupt clear register , Address offset: 4h
◆ IER
__IO uint32_t HSEM_Common_TypeDef::IER
HSEM interrupt enable register , Address offset: 0h
◆ ISR
__IO uint32_t HSEM_Common_TypeDef::ISR
HSEM interrupt status register , Address offset: 8h
◆ MISR
__IO uint32_t HSEM_Common_TypeDef::MISR
HSEM masked interrupt status register , Address offset: Ch
The documentation for this struct was generated from the following files:
