RTEMS 6.1
__IO uint32_t TIMxCR
__IO uint32_t TIMxISR
__IO uint32_t TIMxICR
__IO uint32_t TIMxDIER
__IO uint32_t CNTxR
__IO uint32_t PERxR
__IO uint32_t REPxR
__IO uint32_t CMP1xR
__IO uint32_t CMP1CxR
__IO uint32_t CMP2xR
__IO uint32_t CMP3xR
__IO uint32_t CMP4xR
__IO uint32_t CPT1xR
__IO uint32_t CPT2xR
__IO uint32_t DTxR
__IO uint32_t SETx1R
__IO uint32_t RSTx1R
__IO uint32_t SETx2R
__IO uint32_t RSTx2R
__IO uint32_t EEFxR1
__IO uint32_t EEFxR2
__IO uint32_t RSTxR
__IO uint32_t CHPxR
__IO uint32_t CPT1xCR
__IO uint32_t CPT2xCR
__IO uint32_t OUTxR
__IO uint32_t FLTxR
uint32_t RESERVED0 [5]
Field Documentation
◆ CHPxR
__IO uint32_t HRTIM_Timerx_TypeDef::CHPxR
HRTIM Timerx Chopper register, Address offset: 0x58
◆ CMP1CxR
__IO uint32_t HRTIM_Timerx_TypeDef::CMP1CxR
HRTIM Timerx compare 1 compound register, Address offset: 0x20
◆ CMP1xR
__IO uint32_t HRTIM_Timerx_TypeDef::CMP1xR
HRTIM Timerx compare 1 register, Address offset: 0x1C
◆ CMP2xR
__IO uint32_t HRTIM_Timerx_TypeDef::CMP2xR
HRTIM Timerx compare 2 register, Address offset: 0x24
◆ CMP3xR
__IO uint32_t HRTIM_Timerx_TypeDef::CMP3xR
HRTIM Timerx compare 3 register, Address offset: 0x28
◆ CMP4xR
__IO uint32_t HRTIM_Timerx_TypeDef::CMP4xR
HRTIM Timerx compare 4 register, Address offset: 0x2C
◆ CNTxR
__IO uint32_t HRTIM_Timerx_TypeDef::CNTxR
HRTIM Timerx counter register, Address offset: 0x10
◆ CPT1xCR
__IO uint32_t HRTIM_Timerx_TypeDef::CPT1xCR
HRTIM Timerx Capture 1 register, Address offset: 0x5C
◆ CPT1xR
__IO uint32_t HRTIM_Timerx_TypeDef::CPT1xR
HRTIM Timerx capture 1 register, Address offset: 0x30
◆ CPT2xCR
__IO uint32_t HRTIM_Timerx_TypeDef::CPT2xCR
HRTIM Timerx Capture 2 register, Address offset: 0x60
◆ CPT2xR
__IO uint32_t HRTIM_Timerx_TypeDef::CPT2xR
HRTIM Timerx capture 2 register, Address offset: 0x34
◆ DTxR
__IO uint32_t HRTIM_Timerx_TypeDef::DTxR
HRTIM Timerx dead time register, Address offset: 0x38
◆ EEFxR1
__IO uint32_t HRTIM_Timerx_TypeDef::EEFxR1
HRTIM Timerx external event filtering 1 register, Address offset: 0x4C
◆ EEFxR2
__IO uint32_t HRTIM_Timerx_TypeDef::EEFxR2
HRTIM Timerx external event filtering 2 register, Address offset: 0x50
◆ FLTxR
__IO uint32_t HRTIM_Timerx_TypeDef::FLTxR
HRTIM Timerx Fault register, Address offset: 0x68
◆ OUTxR
__IO uint32_t HRTIM_Timerx_TypeDef::OUTxR
HRTIM Timerx Output register, Address offset: 0x64
◆ PERxR
__IO uint32_t HRTIM_Timerx_TypeDef::PERxR
HRTIM Timerx period register, Address offset: 0x14
◆ REPxR
__IO uint32_t HRTIM_Timerx_TypeDef::REPxR
HRTIM Timerx repetition register, Address offset: 0x18
◆ RESERVED0
uint32_t HRTIM_Timerx_TypeDef::RESERVED0
Reserved, 0x6C..0x7C
◆ RSTx1R
__IO uint32_t HRTIM_Timerx_TypeDef::RSTx1R
HRTIM Timerx output 1 reset register, Address offset: 0x40
◆ RSTx2R
__IO uint32_t HRTIM_Timerx_TypeDef::RSTx2R
HRTIM Timerx output 2 reset register, Address offset: 0x48
◆ RSTxR
__IO uint32_t HRTIM_Timerx_TypeDef::RSTxR
HRTIM Timerx Reset register, Address offset: 0x54
◆ SETx1R
__IO uint32_t HRTIM_Timerx_TypeDef::SETx1R
HRTIM Timerx output 1 set register, Address offset: 0x3C
◆ SETx2R
__IO uint32_t HRTIM_Timerx_TypeDef::SETx2R
HRTIM Timerx output 2 set register, Address offset: 0x44
◆ TIMxCR
__IO uint32_t HRTIM_Timerx_TypeDef::TIMxCR
HRTIM Timerx control register, Address offset: 0x00
◆ TIMxDIER
__IO uint32_t HRTIM_Timerx_TypeDef::TIMxDIER
HRTIM Timerx DMA/interrupt enable register, Address offset: 0x0C
◆ TIMxICR
__IO uint32_t HRTIM_Timerx_TypeDef::TIMxICR
HRTIM Timerx interrupt clear register, Address offset: 0x08
◆ TIMxISR
__IO uint32_t HRTIM_Timerx_TypeDef::TIMxISR
HRTIM Timerx interrupt status register, Address offset: 0x04
The documentation for this struct was generated from the following files:
