RTEMS 6.1
High resolution Timer (HRTIM) More...
#include <stm32h742xx.h>
__IO uint32_t MCR
__IO uint32_t MISR
__IO uint32_t MICR
__IO uint32_t MDIER
__IO uint32_t MCNTR
__IO uint32_t MPER
__IO uint32_t MREP
__IO uint32_t MCMP1R
uint32_t RESERVED0
__IO uint32_t MCMP2R
__IO uint32_t MCMP3R
__IO uint32_t MCMP4R
uint32_t RESERVED1 [20]
Field Documentation
◆ MCMP1R
__IO uint32_t HRTIM_Master_TypeDef::MCMP1R
HRTIM Master Timer compare 1 register, Address offset: 0x1C
◆ MCMP2R
__IO uint32_t HRTIM_Master_TypeDef::MCMP2R
HRTIM Master Timer compare 2 register, Address offset: 0x24
◆ MCMP3R
__IO uint32_t HRTIM_Master_TypeDef::MCMP3R
HRTIM Master Timer compare 3 register, Address offset: 0x28
◆ MCMP4R
__IO uint32_t HRTIM_Master_TypeDef::MCMP4R
HRTIM Master Timer compare 4 register, Address offset: 0x2C
◆ MCNTR
__IO uint32_t HRTIM_Master_TypeDef::MCNTR
HRTIM Master Timer counter register, Address offset: 0x10
◆ MCR
__IO uint32_t HRTIM_Master_TypeDef::MCR
HRTIM Master Timer control register, Address offset: 0x00
◆ MDIER
__IO uint32_t HRTIM_Master_TypeDef::MDIER
HRTIM Master Timer DMA/interrupt enable register Address offset: 0x0C
◆ MICR
__IO uint32_t HRTIM_Master_TypeDef::MICR
HRTIM Master Timer interrupt clear register, Address offset: 0x08
◆ MISR
__IO uint32_t HRTIM_Master_TypeDef::MISR
HRTIM Master Timer interrupt status register, Address offset: 0x04
◆ MPER
__IO uint32_t HRTIM_Master_TypeDef::MPER
HRTIM Master Timer period register, Address offset: 0x14
◆ MREP
__IO uint32_t HRTIM_Master_TypeDef::MREP
HRTIM Master Timer repetition register, Address offset: 0x18
◆ RESERVED0
uint32_t HRTIM_Master_TypeDef::RESERVED0
Reserved, 0x20
◆ RESERVED1
uint32_t HRTIM_Master_TypeDef::RESERVED1
Reserved, 0x30..0x7C
The documentation for this struct was generated from the following files:
