RTEMS 6.1
__IO uint32_t CR1
__IO uint32_t CR2
__IO uint32_t ISR
__IO uint32_t ICR
__IO uint32_t IER
__IO uint32_t OENR
__IO uint32_t ODISR
__IO uint32_t ODSR
__IO uint32_t BMCR
__IO uint32_t BMTRGR
__IO uint32_t BMCMPR
__IO uint32_t BMPER
__IO uint32_t EECR1
__IO uint32_t EECR2
__IO uint32_t EECR3
__IO uint32_t ADC1R
__IO uint32_t ADC2R
__IO uint32_t ADC3R
__IO uint32_t ADC4R
__IO uint32_t RESERVED0
__IO uint32_t FLTINR1
__IO uint32_t FLTINR2
__IO uint32_t BDMUPR
__IO uint32_t BDTAUPR
__IO uint32_t BDTBUPR
__IO uint32_t BDTCUPR
__IO uint32_t BDTDUPR
__IO uint32_t BDTEUPR
__IO uint32_t BDMADR
Field Documentation
◆ ADC1R
__IO uint32_t HRTIM_Common_TypeDef::ADC1R
HRTIM ADC Trigger 1 register, Address offset: 0x3C
◆ ADC2R
__IO uint32_t HRTIM_Common_TypeDef::ADC2R
HRTIM ADC Trigger 2 register, Address offset: 0x40
◆ ADC3R
__IO uint32_t HRTIM_Common_TypeDef::ADC3R
HRTIM ADC Trigger 3 register, Address offset: 0x44
◆ ADC4R
__IO uint32_t HRTIM_Common_TypeDef::ADC4R
HRTIM ADC Trigger 4 register, Address offset: 0x48
◆ BDMADR
__IO uint32_t HRTIM_Common_TypeDef::BDMADR
HRTIM Burst DMA Master Data register, Address offset: 0x70
◆ BDMUPR
__IO uint32_t HRTIM_Common_TypeDef::BDMUPR
HRTIM Burst DMA Master Timer update register, Address offset: 0x58
◆ BDTAUPR
__IO uint32_t HRTIM_Common_TypeDef::BDTAUPR
HRTIM Burst DMA Timerx update register, Address offset: 0x5C
◆ BDTBUPR
__IO uint32_t HRTIM_Common_TypeDef::BDTBUPR
HRTIM Burst DMA Timerx update register, Address offset: 0x60
◆ BDTCUPR
__IO uint32_t HRTIM_Common_TypeDef::BDTCUPR
HRTIM Burst DMA Timerx update register, Address offset: 0x64
◆ BDTDUPR
__IO uint32_t HRTIM_Common_TypeDef::BDTDUPR
HRTIM Burst DMA Timerx update register, Address offset: 0x68
◆ BDTEUPR
__IO uint32_t HRTIM_Common_TypeDef::BDTEUPR
HRTIM Burst DMA Timerx update register, Address offset: 0x6C
◆ BMCMPR
__IO uint32_t HRTIM_Common_TypeDef::BMCMPR
HRTIM Burst mode compare register, Address offset: 0x28
◆ BMCR
__IO uint32_t HRTIM_Common_TypeDef::BMCR
HRTIM Burst mode control register, Address offset: 0x20
◆ BMPER
__IO uint32_t HRTIM_Common_TypeDef::BMPER
HRTIM Burst mode period register, Address offset: 0x2C
◆ BMTRGR
__IO uint32_t HRTIM_Common_TypeDef::BMTRGR
HRTIM Burst mode trigger register, Address offset: 0x24
◆ CR1
__IO uint32_t HRTIM_Common_TypeDef::CR1
HRTIM control register1, Address offset: 0x00
◆ CR2
__IO uint32_t HRTIM_Common_TypeDef::CR2
HRTIM control register2, Address offset: 0x04
◆ EECR1
__IO uint32_t HRTIM_Common_TypeDef::EECR1
HRTIM Timer external event control register1, Address offset: 0x30
◆ EECR2
__IO uint32_t HRTIM_Common_TypeDef::EECR2
HRTIM Timer external event control register2, Address offset: 0x34
◆ EECR3
__IO uint32_t HRTIM_Common_TypeDef::EECR3
HRTIM Timer external event control register3, Address offset: 0x38
◆ FLTINR1
__IO uint32_t HRTIM_Common_TypeDef::FLTINR1
HRTIM Fault input register1, Address offset: 0x50
◆ FLTINR2
__IO uint32_t HRTIM_Common_TypeDef::FLTINR2
HRTIM Fault input register2, Address offset: 0x54
◆ ICR
__IO uint32_t HRTIM_Common_TypeDef::ICR
HRTIM interrupt clear register, Address offset: 0x0C
◆ IER
__IO uint32_t HRTIM_Common_TypeDef::IER
HRTIM interrupt enable register, Address offset: 0x10
◆ ISR
__IO uint32_t HRTIM_Common_TypeDef::ISR
HRTIM interrupt status register, Address offset: 0x08
◆ ODISR
__IO uint32_t HRTIM_Common_TypeDef::ODISR
HRTIM Output disable register, Address offset: 0x18
◆ ODSR
__IO uint32_t HRTIM_Common_TypeDef::ODSR
HRTIM Output disable status register, Address offset: 0x1C
◆ OENR
__IO uint32_t HRTIM_Common_TypeDef::OENR
HRTIM Output enable register, Address offset: 0x14
◆ RESERVED0
__IO uint32_t HRTIM_Common_TypeDef::RESERVED0
Reserved, Address offset: 0x4C
The documentation for this struct was generated from the following files:
