RTEMS 6.1
HAL DMAMUX Synchronization configuration structure definition. More...
#include <stm32h7xx_hal_dma_ex.h>
Data Fields | |
| uint32_t | SyncSignalID |
| uint32_t | SyncPolarity |
| FunctionalState | SyncEnable |
| FunctionalState | EventEnable |
| uint32_t | RequestNumber |
| FunctionalState HAL_DMA_MuxSyncConfigTypeDef::EventEnable |
Specifies if an event shall be generated once the RequestNumber is reached. This parameter can take the value ENABLE or DISABLE
| uint32_t HAL_DMA_MuxSyncConfigTypeDef::RequestNumber |
Specifies the number of DMA request that will be authorized after a sync event. This parameters can be in the range 1 to 32
| FunctionalState HAL_DMA_MuxSyncConfigTypeDef::SyncEnable |
Specifies if the synchronization shall be enabled or disabled This parameter can take the value ENABLE or DISABLE
| uint32_t HAL_DMA_MuxSyncConfigTypeDef::SyncPolarity |
Specifies the polarity of the signal on which the DMA request is synchronized. This parameter can be a value of DMAEx MUX SyncPolarity selection
| uint32_t HAL_DMA_MuxSyncConfigTypeDef::SyncSignalID |
Specifies the synchronization signal gating the DMA request in periodic mode. This parameter can be a value of DMAEx MUX SyncSignalID selection
