RTEMS 6.1
Global Programmer View. More...
#include <stm32h723xx.h>
| __IO uint32_t GPV_TypeDef::AXI_COMP_ID_0 |
AXI interconnect - component ID0 register, Address offset: 0x1FF0
| __IO uint32_t GPV_TypeDef::AXI_COMP_ID_1 |
AXI interconnect - component ID1 register, Address offset: 0x1FF4
| __IO uint32_t GPV_TypeDef::AXI_COMP_ID_2 |
AXI interconnect - component ID2 register, Address offset: 0x1FF8
| __IO uint32_t GPV_TypeDef::AXI_COMP_ID_3 |
AXI interconnect - component ID3 register, Address offset: 0x1FFC
| __IO uint32_t GPV_TypeDef::AXI_INI1_FN_MOD |
AXI interconnect - INI 1 issuing functionality modification register, Address offset: 0x42108
| __IO uint32_t GPV_TypeDef::AXI_INI1_FN_MOD2 |
AXI interconnect - INI 1 functionality modification 2 register, Address offset: 0x42024
| __IO uint32_t GPV_TypeDef::AXI_INI1_FN_MOD_AHB |
AXI interconnect - INI 1 AHB functionality modification register, Address offset: 0x42028
| __IO uint32_t GPV_TypeDef::AXI_INI1_READ_QOS |
AXI interconnect - INI 1 read QoS register, Address offset: 0x42100
| __IO uint32_t GPV_TypeDef::AXI_INI1_WRITE_QOS |
AXI interconnect - INI 1 write QoS register, Address offset: 0x42104
| __IO uint32_t GPV_TypeDef::AXI_INI2_FN_MOD |
AXI interconnect - INI 2 issuing functionality modification register, Address offset: 0x43108
| __IO uint32_t GPV_TypeDef::AXI_INI2_READ_QOS |
AXI interconnect - INI 2 read QoS register, Address offset: 0x43100
| __IO uint32_t GPV_TypeDef::AXI_INI2_WRITE_QOS |
AXI interconnect - INI 2 write QoS register, Address offset: 0x43104
| __IO uint32_t GPV_TypeDef::AXI_INI3_FN_MOD |
AXI interconnect - INI 3 issuing functionality modification register, Address offset: 0x44108
| __IO uint32_t GPV_TypeDef::AXI_INI3_FN_MOD2 |
AXI interconnect - INI 3 functionality modification 2 register, Address offset: 0x44024
| __IO uint32_t GPV_TypeDef::AXI_INI3_FN_MOD_AHB |
AXI interconnect - INI 3 AHB functionality modification register, Address offset: 0x44028
| __IO uint32_t GPV_TypeDef::AXI_INI3_READ_QOS |
AXI interconnect - INI 3 read QoS register, Address offset: 0x44100
| __IO uint32_t GPV_TypeDef::AXI_INI3_WRITE_QOS |
AXI interconnect - INI 3 write QoS register, Address offset: 0x44104
| __IO uint32_t GPV_TypeDef::AXI_INI4_FN_MOD |
AXI interconnect - INI 4 issuing functionality modification register, Address offset: 0x45108
| __IO uint32_t GPV_TypeDef::AXI_INI4_READ_QOS |
AXI interconnect - INI 4 read QoS register, Address offset: 0x45100
| __IO uint32_t GPV_TypeDef::AXI_INI4_WRITE_QOS |
AXI interconnect - INI 4 write QoS register, Address offset: 0x45104
| __IO uint32_t GPV_TypeDef::AXI_INI5_FN_MOD |
AXI interconnect - INI 5 issuing functionality modification register, Address offset: 0x46108
| __IO uint32_t GPV_TypeDef::AXI_INI5_READ_QOS |
AXI interconnect - INI 5 read QoS register, Address offset: 0x46100
| __IO uint32_t GPV_TypeDef::AXI_INI5_WRITE_QOS |
AXI interconnect - INI 5 write QoS register, Address offset: 0x46104
| __IO uint32_t GPV_TypeDef::AXI_INI6_FN_MOD |
AXI interconnect - INI 6 issuing functionality modification register, Address offset: 0x47108
| __IO uint32_t GPV_TypeDef::AXI_INI6_READ_QOS |
AXI interconnect - INI 6 read QoS register, Address offset: 0x47100
| __IO uint32_t GPV_TypeDef::AXI_INI6_WRITE_QOS |
AXI interconnect - INI 6 write QoS register, Address offset: 0x47104
| __IO uint32_t GPV_TypeDef::AXI_INI7_FN_MOD |
AXI interconnect - INI 7 issuing functionality modification register, Address offset: 0x48108
| __IO uint32_t GPV_TypeDef::AXI_INI7_FN_MOD2 |
AXI interconnect - INI 7 functionality modification 2 register, Address offset: 0x48024
| __IO uint32_t GPV_TypeDef::AXI_INI7_FN_MOD_AHB |
AXI interconnect - INI 7 AHB functionality modification register, Address offset: 0x48028
| __IO uint32_t GPV_TypeDef::AXI_INI7_READ_QOS |
AXI interconnect - INI 7 read QoS register, Address offset: 0x48100
| __IO uint32_t GPV_TypeDef::AXI_INI7_WRITE_QOS |
AXI interconnect - INI 7 write QoS register, Address offset: 0x48104
| __IO uint32_t GPV_TypeDef::AXI_PERIPH_ID_0 |
AXI interconnect - peripheral ID0 register, Address offset: 0x1FE0
| __IO uint32_t GPV_TypeDef::AXI_PERIPH_ID_1 |
AXI interconnect - peripheral ID1 register, Address offset: 0x1FE4
| __IO uint32_t GPV_TypeDef::AXI_PERIPH_ID_2 |
AXI interconnect - peripheral ID2 register, Address offset: 0x1FE8
| __IO uint32_t GPV_TypeDef::AXI_PERIPH_ID_3 |
AXI interconnect - peripheral ID3 register, Address offset: 0x1FEC
| __IO uint32_t GPV_TypeDef::AXI_PERIPH_ID_4 |
AXI interconnect - peripheral ID4 register, Address offset: 0x1FD0
| uint32_t GPV_TypeDef::AXI_PERIPH_ID_5 |
Reserved, Address offset: 0x1FD4
| uint32_t GPV_TypeDef::AXI_PERIPH_ID_6 |
Reserved, Address offset: 0x1FD8
| uint32_t GPV_TypeDef::AXI_PERIPH_ID_7 |
Reserved, Address offset: 0x1FDC
| __IO uint32_t GPV_TypeDef::AXI_TARG10_FN_MOD |
AXI interconnect - TARG 10 issuing functionality modification register, Address offset: 0xB108
| __IO uint32_t GPV_TypeDef::AXI_TARG10_FN_MOD2 |
AXI interconnect - TARG 10 bus matrix functionality 2 register, Address offset: 0xB024
| __IO uint32_t GPV_TypeDef::AXI_TARG10_FN_MOD_ISS_BM |
AXI interconnect - TARG 10 bus matrix issuing functionality register, Address offset: 0xB008
| __IO uint32_t GPV_TypeDef::AXI_TARG10_FN_MOD_LB |
AXI interconnect - TARG 10 long burst functionality modification register, Address offset: 0xC02C
| __IO uint32_t GPV_TypeDef::AXI_TARG1_FN_MOD |
AXI interconnect - TARG 1 issuing functionality modification register, Address offset: 0x2108
| __IO uint32_t GPV_TypeDef::AXI_TARG1_FN_MOD2 |
AXI interconnect - TARG 1 bus matrix functionality 2 register, Address offset: 0x2024
| __IO uint32_t GPV_TypeDef::AXI_TARG1_FN_MOD_ISS_BM |
AXI interconnect - TARG 1 bus matrix issuing functionality register, Address offset: 0x2008
| __IO uint32_t GPV_TypeDef::AXI_TARG1_FN_MOD_LB |
AXI interconnect - TARG 1 long burst functionality modification register, Address offset: 0x202C
| __IO uint32_t GPV_TypeDef::AXI_TARG2_FN_MOD |
AXI interconnect - TARG 2 issuing functionality modification register, Address offset: 0x3108
| __IO uint32_t GPV_TypeDef::AXI_TARG2_FN_MOD2 |
AXI interconnect - TARG 2 bus matrix functionality 2 register, Address offset: 0x3024
| __IO uint32_t GPV_TypeDef::AXI_TARG2_FN_MOD_ISS_BM |
AXI interconnect - TARG 2 bus matrix issuing functionality register, Address offset: 0x3008
| __IO uint32_t GPV_TypeDef::AXI_TARG2_FN_MOD_LB |
AXI interconnect - TARG 2 long burst functionality modification register, Address offset: 0x302C
| __IO uint32_t GPV_TypeDef::AXI_TARG3_FN_MOD_ISS_BM |
AXI interconnect - TARG 3 bus matrix issuing functionality register, Address offset: 0x4008
| __IO uint32_t GPV_TypeDef::AXI_TARG4_FN_MOD_ISS_BM |
AXI interconnect - TARG 4 bus matrix issuing functionality register, Address offset: 0x5008
| __IO uint32_t GPV_TypeDef::AXI_TARG5_FN_MOD_ISS_BM |
AXI interconnect - TARG 5 bus matrix issuing functionality register, Address offset: 0x6008
| __IO uint32_t GPV_TypeDef::AXI_TARG6_FN_MOD_ISS_BM |
AXI interconnect - TARG 6 bus matrix issuing functionality register, Address offset: 0x7008
| __IO uint32_t GPV_TypeDef::AXI_TARG7_FN_MOD |
AXI interconnect - TARG 7 issuing functionality modification register, Address offset: 0x8108
| __IO uint32_t GPV_TypeDef::AXI_TARG7_FN_MOD2 |
AXI interconnect - TARG 7 bus matrix functionality 2 register, Address offset: 0x8024
| __IO uint32_t GPV_TypeDef::AXI_TARG7_FN_MOD_ISS_BM |
AXI interconnect - TARG 7 bus matrix issuing functionality register, Address offset: 0x8008
| __IO uint32_t GPV_TypeDef::AXI_TARG7_FN_MOD_LB |
AXI interconnect - TARG 7 long burst functionality modification register, Address offset: 0x802C
| __IO uint32_t GPV_TypeDef::AXI_TARG8_FN_MOD |
AXI interconnect - TARG 8 issuing functionality modification register, Address offset: 0x9108
| __IO uint32_t GPV_TypeDef::AXI_TARG8_FN_MOD2 |
AXI interconnect - TARG 8 bus matrix functionality 2 register, Address offset: 0x9024
| __IO uint32_t GPV_TypeDef::AXI_TARG8_FN_MOD_ISS_BM |
AXI interconnect - TARG 8 bus matrix issuing functionality register, Address offset: 0x9008
| __IO uint32_t GPV_TypeDef::AXI_TARG9_FN_MOD |
AXI interconnect - TARG 9 issuing functionality modification register, Address offset: 0xA108
| __IO uint32_t GPV_TypeDef::AXI_TARG9_FN_MOD2 |
AXI interconnect - TARG 9 bus matrix functionality 2 register, Address offset: 0xA024
| __IO uint32_t GPV_TypeDef::AXI_TARG9_FN_MOD_ISS_BM |
AXI interconnect - TARG 9 bus matrix issuing functionality register, Address offset: 0xA008
| uint32_t GPV_TypeDef::RESERVED0 |
Reserved, Address offset: 0x00-0x1FCC
| uint32_t GPV_TypeDef::RESERVED1 |
Reserved, Address offset: 0x2000-0x2004
| uint32_t GPV_TypeDef::RESERVED10 |
Reserved, Address offset: 0x400C-0x5004
| uint32_t GPV_TypeDef::RESERVED11 |
Reserved, Address offset: 0x500C-0x6004
| uint32_t GPV_TypeDef::RESERVED117 |
Reserved, Address offset: 0x900C-0x9020
| uint32_t GPV_TypeDef::RESERVED118 |
Reserved, Address offset: 0x9028-0x9104
| uint32_t GPV_TypeDef::RESERVED119 |
Reserved, Address offset: 0x910C-0x42020
Reserved, Address offset: 0x910C-0xA004
| uint32_t GPV_TypeDef::RESERVED12 |
Reserved, Address offset: 0x600C-0x7004
| uint32_t GPV_TypeDef::RESERVED120 |
Reserved, Address offset: 0xA00C-0xA020
| uint32_t GPV_TypeDef::RESERVED121 |
Reserved, Address offset: 0xA028-0xA104
| uint32_t GPV_TypeDef::RESERVED122 |
Reserved, Address offset: 0xA10C-0xB004
| uint32_t GPV_TypeDef::RESERVED123 |
Reserved, Address offset: 0xB00C-0xB020
| uint32_t GPV_TypeDef::RESERVED124 |
Reserved, Address offset: 0xB028-0xB104
| uint32_t GPV_TypeDef::RESERVED125 |
Reserved, Address offset: 0xB10C-0xC028
| uint32_t GPV_TypeDef::RESERVED126 |
Reserved, Address offset: 0xC030-0xC104
| uint32_t GPV_TypeDef::RESERVED13 |
Reserved, Address offset: 0x700C-0x8004
| uint32_t GPV_TypeDef::RESERVED14 |
Reserved, Address offset: 0x800C-0x8020
| uint32_t GPV_TypeDef::RESERVED15 |
Reserved, Address offset: 0x8028
| uint32_t GPV_TypeDef::RESERVED16 |
Reserved, Address offset: 0x8030-0x8104
| uint32_t GPV_TypeDef::RESERVED17 |
Reserved, Address offset: 0x810C-0x9004
Reserved, Address offset: 0x810C-0x42020
| uint32_t GPV_TypeDef::RESERVED18 |
Reserved, Address offset: 0x4202C-0x420FC
| uint32_t GPV_TypeDef::RESERVED19 |
Reserved, Address offset: 0x4210C-0x430FC
| uint32_t GPV_TypeDef::RESERVED2 |
Reserved, Address offset: 0x200C-0x2020
| uint32_t GPV_TypeDef::RESERVED20 |
Reserved, Address offset: 0x4310C-0x44020
| uint32_t GPV_TypeDef::RESERVED21 |
Reserved, Address offset: 0x4402C-0x440FC
| uint32_t GPV_TypeDef::RESERVED22 |
Reserved, Address offset: 0x4410C-0x450FC
| uint32_t GPV_TypeDef::RESERVED23 |
Reserved, Address offset: 0x4510C-0x460FC
| uint32_t GPV_TypeDef::RESERVED24 |
Reserved, Address offset: 0x4610C-0x470FC
| uint32_t GPV_TypeDef::RESERVED25 |
Reserved, Address offset: 0x4710C-0x480FC
Reserved, Address offset: 0x4710C-0x48020
| uint32_t GPV_TypeDef::RESERVED26 |
Reserved, Address offset: 0x4802C-0x480FC
| uint32_t GPV_TypeDef::RESERVED3 |
Reserved, Address offset: 0x2028
| uint32_t GPV_TypeDef::RESERVED4 |
Reserved, Address offset: 0x2030-0x2104
| uint32_t GPV_TypeDef::RESERVED5 |
Reserved, Address offset: 0x210C-0x3004
| uint32_t GPV_TypeDef::RESERVED6 |
Reserved, Address offset: 0x300C-0x3020
| uint32_t GPV_TypeDef::RESERVED7 |
Reserved, Address offset: 0x3028
| uint32_t GPV_TypeDef::RESERVED8 |
Reserved, Address offset: 0x3030-0x3104
| uint32_t GPV_TypeDef::RESERVED9 |
Reserved, Address offset: 0x310C-0x4004
