RTEMS 6.1
General Purpose I/O. More...
#include <stm32h723xx.h>
__IO uint32_t MODER
__IO uint32_t OTYPER
__IO uint32_t OSPEEDR
__IO uint32_t PUPDR
__IO uint32_t IDR
__IO uint32_t ODR
__IO uint32_t BSRR
__IO uint32_t LCKR
__IO uint32_t AFR [2]
Field Documentation
◆ AFR
__IO uint32_t GPIO_TypeDef::AFR
GPIO alternate function registers, Address offset: 0x20-0x24
◆ BSRR
__IO uint32_t GPIO_TypeDef::BSRR
GPIO port bit set/reset, Address offset: 0x18
◆ IDR
__IO uint32_t GPIO_TypeDef::IDR
GPIO port input data register, Address offset: 0x10
◆ LCKR
__IO uint32_t GPIO_TypeDef::LCKR
GPIO port configuration lock register, Address offset: 0x1C
◆ MODER
__IO uint32_t GPIO_TypeDef::MODER
GPIO port mode register, Address offset: 0x00
◆ ODR
__IO uint32_t GPIO_TypeDef::ODR
GPIO port output data register, Address offset: 0x14
◆ OSPEEDR
__IO uint32_t GPIO_TypeDef::OSPEEDR
GPIO port output speed register, Address offset: 0x08
◆ OTYPER
__IO uint32_t GPIO_TypeDef::OTYPER
GPIO port output type register, Address offset: 0x04
◆ PUPDR
__IO uint32_t GPIO_TypeDef::PUPDR
GPIO port pull-up/pull-down register, Address offset: 0x0C
The documentation for this struct was generated from the following files:
