RTEMS 6.1
#include <MIMXRT1166_cm4.h>
uint8_t RESERVED_0 [4]
__IO uint32_t SP_AUTHEN_CTRL
__IO uint32_t SP_INT_CTRL
uint8_t RESERVED_1 [4]
__I uint32_t SP_CPU_REQ
__I uint32_t SP_SYS_STAT
uint8_t RESERVED_2 [4]
__IO uint32_t SP_ROSC_CTRL
uint8_t RESERVED_3 [32]
__IO uint32_t SP_PRIORITY_0_7
__IO uint32_t SP_PRIORITY_8_15
uint8_t RESERVED_4 [184]
__IO uint32_t SP_SSAR_SAVE_CTRL
uint8_t RESERVED_5 [12]
__IO uint32_t SP_LPCG_OFF_CTRL
uint8_t RESERVED_6 [12]
__IO uint32_t SP_GROUP_DOWN_CTRL
uint8_t RESERVED_7 [12]
__IO uint32_t SP_ROOT_DOWN_CTRL
uint8_t RESERVED_8 [12]
__IO uint32_t SP_PLL_OFF_CTRL
uint8_t RESERVED_9 [12]
__IO uint32_t SP_ISO_ON_CTRL
uint8_t RESERVED_10 [12]
__IO uint32_t SP_RESET_EARLY_CTRL
uint8_t RESERVED_11 [12]
__IO uint32_t SP_POWER_OFF_CTRL
uint8_t RESERVED_12 [12]
__IO uint32_t SP_BIAS_OFF_CTRL
uint8_t RESERVED_13 [12]
__IO uint32_t SP_BG_PLDO_OFF_CTRL
uint8_t RESERVED_14 [12]
__IO uint32_t SP_LDO_PRE_CTRL
uint8_t RESERVED_15 [12]
__IO uint32_t SP_DCDC_DOWN_CTRL
uint8_t RESERVED_16 [76]
__IO uint32_t SP_DCDC_UP_CTRL
uint8_t RESERVED_17 [12]
__IO uint32_t SP_LDO_POST_CTRL
uint8_t RESERVED_18 [12]
__IO uint32_t SP_BG_PLDO_ON_CTRL
uint8_t RESERVED_19 [12]
__IO uint32_t SP_BIAS_ON_CTRL
uint8_t RESERVED_20 [12]
__IO uint32_t SP_POWER_ON_CTRL
uint8_t RESERVED_21 [12]
__IO uint32_t SP_RESET_LATE_CTRL
uint8_t RESERVED_22 [12]
__IO uint32_t SP_ISO_OFF_CTRL
uint8_t RESERVED_23 [12]
__IO uint32_t SP_PLL_ON_CTRL
uint8_t RESERVED_24 [12]
__IO uint32_t SP_ROOT_UP_CTRL
uint8_t RESERVED_25 [12]
__IO uint32_t SP_GROUP_UP_CTRL
uint8_t RESERVED_26 [12]
__IO uint32_t SP_LPCG_ON_CTRL
uint8_t RESERVED_27 [12]
__IO uint32_t SP_SSAR_RESTORE_CTRL
GPC_SET_POINT_CTRL - Register Layout Typedef
The documentation for this struct was generated from the following files:
