RTEMS 6.1
GFXMMU registers. More...
#include <stm32h7a3xx.h>
__IO uint32_t CR
__IO uint32_t SR
__IO uint32_t FCR
__IO uint32_t CCR
__IO uint32_t DVR
uint32_t RESERVED1 [3]
__IO uint32_t B0CR
__IO uint32_t B1CR
__IO uint32_t B2CR
__IO uint32_t B3CR
uint32_t RESERVED2 [1012]
__IO uint32_t LUT [2048]
GFXMMU registers.
Field Documentation
◆ B0CR
__IO uint32_t GFXMMU_TypeDef::B0CR
GFXMMU buffer 0 configuration register, Address offset: 0x20
◆ B1CR
__IO uint32_t GFXMMU_TypeDef::B1CR
GFXMMU buffer 1 configuration register, Address offset: 0x24
◆ B2CR
__IO uint32_t GFXMMU_TypeDef::B2CR
GFXMMU buffer 2 configuration register, Address offset: 0x28
◆ B3CR
__IO uint32_t GFXMMU_TypeDef::B3CR
GFXMMU buffer 3 configuration register, Address offset: 0x2C
◆ CCR
__IO uint32_t GFXMMU_TypeDef::CCR
GFXMMU Cache Control Register, Address offset: 0x0C
◆ CR
__IO uint32_t GFXMMU_TypeDef::CR
GFXMMU configuration register, Address offset: 0x00
◆ DVR
__IO uint32_t GFXMMU_TypeDef::DVR
GFXMMU default value register, Address offset: 0x10
◆ FCR
__IO uint32_t GFXMMU_TypeDef::FCR
GFXMMU flag clear register, Address offset: 0x08
◆ LUT
__IO uint32_t GFXMMU_TypeDef::LUT
GFXMMU LUT registers, Address offset: 0x1000 to 0x2FFC For LUT line i, LUTiL = LUT[2*i] and LUTiH = LUT[(2*i)+1]
◆ RESERVED1
uint32_t GFXMMU_TypeDef::RESERVED1
Reserved1, Address offset: 0x14 to 0x1C
◆ RESERVED2
uint32_t GFXMMU_TypeDef::RESERVED2
Reserved2, Address offset: 0x30 to 0xFFC
◆ SR
__IO uint32_t GFXMMU_TypeDef::SR
GFXMMU status register, Address offset: 0x04
The documentation for this struct was generated from the following files:
