RTEMS 6.1
Flexible Memory Controller Bank2. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | PCR2 |
| __IO uint32_t | SR2 |
| __IO uint32_t | PMEM2 |
| __IO uint32_t | PATT2 |
| uint32_t | RESERVED0 |
| __IO uint32_t | ECCR2 |
| __IO uint32_t FMC_Bank2_TypeDef::ECCR2 |
NAND Flash ECC result registers 2, Address offset: 0x74
| __IO uint32_t FMC_Bank2_TypeDef::PATT2 |
NAND Flash Attribute memory space timing register 2, Address offset: 0x6C
| __IO uint32_t FMC_Bank2_TypeDef::PCR2 |
NAND Flash control register 2, Address offset: 0x60
| __IO uint32_t FMC_Bank2_TypeDef::PMEM2 |
NAND Flash Common memory space timing register 2, Address offset: 0x68
| uint32_t FMC_Bank2_TypeDef::RESERVED0 |
Reserved, 0x70
| __IO uint32_t FMC_Bank2_TypeDef::SR2 |
NAND Flash FIFO status and interrupt register 2, Address offset: 0x64
