RTEMS 6.1
Filter and Mathematical ACcelerator. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | X1BUFCFG |
| __IO uint32_t | X2BUFCFG |
| __IO uint32_t | YBUFCFG |
| __IO uint32_t | PARAM |
| __IO uint32_t | CR |
| __IO uint32_t | SR |
| __IO uint32_t | WDATA |
| __IO uint32_t | RDATA |
| __IO uint32_t FMAC_TypeDef::CR |
FMAC Control register, Address offset: 0x10
| __IO uint32_t FMAC_TypeDef::PARAM |
FMAC Parameter register, Address offset: 0x0C
| __IO uint32_t FMAC_TypeDef::RDATA |
FMAC Read Data register, Address offset: 0x1C
| __IO uint32_t FMAC_TypeDef::SR |
FMAC Status register, Address offset: 0x14
| __IO uint32_t FMAC_TypeDef::WDATA |
FMAC Write Data register, Address offset: 0x18
| __IO uint32_t FMAC_TypeDef::X1BUFCFG |
FMAC X1 Buffer Configuration register, Address offset: 0x00
| __IO uint32_t FMAC_TypeDef::X2BUFCFG |
FMAC X2 Buffer Configuration register, Address offset: 0x04
| __IO uint32_t FMAC_TypeDef::YBUFCFG |
FMAC Y Buffer Configuration register, Address offset: 0x08
