RTEMS
6.1
FLEXRAM_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
FLEXRAM Peripheral Access Layer
MIMXRT1052.h
__IO
uint32_t
TCM_CTRL
uint8_t
RESERVED_0
[12]
__IO
uint32_t
INT_STATUS
__IO
uint32_t
INT_STAT_EN
__IO
uint32_t
INT_SIG_EN
__IO
uint32_t
OCRAM_MAGIC_ADDR
__IO
uint32_t
DTCM_MAGIC_ADDR
__IO
uint32_t
ITCM_MAGIC_ADDR
__I
uint32_t
OCRAM_ECC_SINGLE_ERROR_INFO
__I
uint32_t
OCRAM_ECC_SINGLE_ERROR_ADDR
__I
uint32_t
OCRAM_ECC_SINGLE_ERROR_DATA_LSB
__I
uint32_t
OCRAM_ECC_SINGLE_ERROR_DATA_MSB
__I
uint32_t
OCRAM_ECC_MULTI_ERROR_INFO
__I
uint32_t
OCRAM_ECC_MULTI_ERROR_ADDR
__I
uint32_t
OCRAM_ECC_MULTI_ERROR_DATA_LSB
__I
uint32_t
OCRAM_ECC_MULTI_ERROR_DATA_MSB
__I
uint32_t
ITCM_ECC_SINGLE_ERROR_INFO
__I
uint32_t
ITCM_ECC_SINGLE_ERROR_ADDR
__I
uint32_t
ITCM_ECC_SINGLE_ERROR_DATA_LSB
__I
uint32_t
ITCM_ECC_SINGLE_ERROR_DATA_MSB
__I
uint32_t
ITCM_ECC_MULTI_ERROR_INFO
__I
uint32_t
ITCM_ECC_MULTI_ERROR_ADDR
__I
uint32_t
ITCM_ECC_MULTI_ERROR_DATA_LSB
__I
uint32_t
ITCM_ECC_MULTI_ERROR_DATA_MSB
__I
uint32_t
D0TCM_ECC_SINGLE_ERROR_INFO
__I
uint32_t
D0TCM_ECC_SINGLE_ERROR_ADDR
__I
uint32_t
D0TCM_ECC_SINGLE_ERROR_DATA
__I
uint32_t
D0TCM_ECC_MULTI_ERROR_INFO
__I
uint32_t
D0TCM_ECC_MULTI_ERROR_ADDR
__I
uint32_t
D0TCM_ECC_MULTI_ERROR_DATA
__I
uint32_t
D1TCM_ECC_SINGLE_ERROR_INFO
__I
uint32_t
D1TCM_ECC_SINGLE_ERROR_ADDR
__I
uint32_t
D1TCM_ECC_SINGLE_ERROR_DATA
__I
uint32_t
D1TCM_ECC_MULTI_ERROR_INFO
__I
uint32_t
D1TCM_ECC_MULTI_ERROR_ADDR
__I
uint32_t
D1TCM_ECC_MULTI_ERROR_DATA
__IO
uint32_t
FLEXRAM_CTRL
__I
uint32_t
OCRAM_PIPELINE_STATUS
FLEXRAM - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/
MIMXRT1052.h
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
