RTEMS 6.1
FLEXCAN2_tag::canbuf_t Struct Reference
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:4
      uint32_t   CODE:4
      uint32_t   __pad1__:1
      uint32_t   SRR:1
      uint32_t   IDE:1
      uint32_t   RTR:1
      uint32_t   LENGTH:4
      uint32_t   TIMESTAMP:16
   }   B
CS
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:3
      uint32_t   STD_ID:11
      uint32_t   EXT_ID:18
   }   B
ID
union {
   uint8_t   B [8]
   uint16_t   H [4]
   uint32_t   W [2]
   uint32_t   R [2]
DATA
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:4
      uint32_t   CODE:4
      uint32_t   __pad1__:1
      uint32_t   SRR:1
      uint32_t   IDE:1
      uint32_t   RTR:1
      uint32_t   LENGTH:4
   }   B
CS
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:3
      uint32_t   STD_ID:11
      uint32_t   EXT_ID:18
   }   B
ID
union {
   uint8_t   B [8]
   uint16_t   H [4]
   uint32_t   W [2]
   uint32_t   R [2]
DATA
union {
   uint32_t   R
   struct {
      uint32_t   __pad0__:4
      uint32_t   CODE:4
      uint32_t   __pad1__:1
      uint32_t   SRR:1
      uint32_t   IDE:1
      uint32_t   RTR:1
      uint32_t   LENGTH:4
   }   B
CS
union {
   uint32_t   R
   struct {
      uint32_t   PRIO:3
      uint32_t   STD_ID:11
      uint32_t   EXT_ID:18
   }   B
ID
union {
   uint8_t   B [8]
   uint16_t   H [4]
   uint32_t   W [2]
   uint32_t   R [2]
DATA
The documentation for this struct was generated from the following files:
