RTEMS 6.1
FLASH Registers. More...
#include <stm32h723xx.h>
__IO uint32_t ACR
__IO uint32_t KEYR1
__IO uint32_t OPTKEYR
__IO uint32_t CR1
__IO uint32_t SR1
__IO uint32_t CCR1
__IO uint32_t OPTCR
__IO uint32_t OPTSR_CUR
__IO uint32_t OPTSR_PRG
__IO uint32_t OPTCCR
__IO uint32_t PRAR_CUR1
__IO uint32_t PRAR_PRG1
__IO uint32_t SCAR_CUR1
__IO uint32_t SCAR_PRG1
__IO uint32_t WPSN_CUR1
__IO uint32_t WPSN_PRG1
__IO uint32_t BOOT_CUR
__IO uint32_t BOOT_PRG
uint32_t RESERVED0 [2]
__IO uint32_t CRCCR1
__IO uint32_t CRCSADD1
__IO uint32_t CRCEADD1
__IO uint32_t CRCDATA
__IO uint32_t ECC_FA1
uint32_t RESERVED [3]
__IO uint32_t OPTSR2_CUR
__IO uint32_t OPTSR2_PRG
uint32_t RESERVED1 [40]
__IO uint32_t KEYR2
uint32_t RESERVED2
__IO uint32_t CR2
__IO uint32_t SR2
__IO uint32_t CCR2
uint32_t RESERVED3 [4]
__IO uint32_t PRAR_CUR2
__IO uint32_t PRAR_PRG2
__IO uint32_t SCAR_CUR2
__IO uint32_t SCAR_PRG2
__IO uint32_t WPSN_CUR2
__IO uint32_t WPSN_PRG2
uint32_t RESERVED4 [4]
__IO uint32_t CRCCR2
__IO uint32_t CRCSADD2
__IO uint32_t CRCEADD2
__IO uint32_t CRCDATA2
__IO uint32_t ECC_FA2
__IO uint32_t BOOT7_CUR
__IO uint32_t BOOT7_PRG
__IO uint32_t BOOT4_CUR
__IO uint32_t BOOT4_PRG
__IO uint32_t OTPBL_CUR
__IO uint32_t OTPBL_PRG
FLASH Registers.
Field Documentation
◆ ACR
__IO uint32_t FLASH_TypeDef::ACR
FLASH access control register, Address offset: 0x00
◆ BOOT4_CUR
__IO uint32_t FLASH_TypeDef::BOOT4_CUR
Flash Current Boot Address for M4 Core Register, Address offset: 0x48
◆ BOOT4_PRG
__IO uint32_t FLASH_TypeDef::BOOT4_PRG
Flash Boot Address to Program for M4 Core Register, Address offset: 0x4C
◆ BOOT7_CUR
__IO uint32_t FLASH_TypeDef::BOOT7_CUR
Flash Current Boot Address for Pelican Core Register, Address offset: 0x40
◆ BOOT7_PRG
__IO uint32_t FLASH_TypeDef::BOOT7_PRG
Flash Boot Address to Program for Pelican Core Register, Address offset: 0x44
◆ BOOT_CUR
__IO uint32_t FLASH_TypeDef::BOOT_CUR
◆ BOOT_PRG
__IO uint32_t FLASH_TypeDef::BOOT_PRG
◆ CCR1
__IO uint32_t FLASH_TypeDef::CCR1
Flash Control Register for bank1, Address offset: 0x14
◆ CCR2
__IO uint32_t FLASH_TypeDef::CCR2
Flash Status Register for bank2, Address offset: 0x114
◆ CR1
__IO uint32_t FLASH_TypeDef::CR1
Flash Control Register for bank1, Address offset: 0x0C
◆ CR2
__IO uint32_t FLASH_TypeDef::CR2
Flash Control Register for bank2, Address offset: 0x10C
◆ CRCCR1
__IO uint32_t FLASH_TypeDef::CRCCR1
Flash CRC Control register For Bank1 Register , Address offset: 0x50
◆ CRCCR2
__IO uint32_t FLASH_TypeDef::CRCCR2
Flash CRC Control register For Bank2 Register , Address offset: 0x150
◆ CRCDATA
__IO uint32_t FLASH_TypeDef::CRCDATA
Flash CRC Data Register for Bank1 , Address offset: 0x5C
◆ CRCDATA2
__IO uint32_t FLASH_TypeDef::CRCDATA2
Flash CRC Data Register for Bank2 , Address offset: 0x15C
◆ CRCEADD1
__IO uint32_t FLASH_TypeDef::CRCEADD1
Flash CRC End Address Register for Bank1 , Address offset: 0x58
◆ CRCEADD2
__IO uint32_t FLASH_TypeDef::CRCEADD2
Flash CRC End Address Register for Bank2 , Address offset: 0x158
◆ CRCSADD1
__IO uint32_t FLASH_TypeDef::CRCSADD1
Flash CRC Start Address Register for Bank1 , Address offset: 0x54
◆ CRCSADD2
__IO uint32_t FLASH_TypeDef::CRCSADD2
Flash CRC Start Address Register for Bank2 , Address offset: 0x154
◆ ECC_FA1
__IO uint32_t FLASH_TypeDef::ECC_FA1
Flash ECC Fail Address For Bank1 Register , Address offset: 0x60
◆ ECC_FA2
__IO uint32_t FLASH_TypeDef::ECC_FA2
Flash ECC Fail Address For Bank2 Register , Address offset: 0x160
◆ KEYR1
__IO uint32_t FLASH_TypeDef::KEYR1
Flash Key Register for bank1, Address offset: 0x04
◆ KEYR2
__IO uint32_t FLASH_TypeDef::KEYR2
Flash Key Register for bank2, Address offset: 0x104
◆ OPTCCR
__IO uint32_t FLASH_TypeDef::OPTCCR
Flash Option Clear Control Register, Address offset: 0x24
◆ OPTCR
__IO uint32_t FLASH_TypeDef::OPTCR
Flash Option Control Register, Address offset: 0x18
◆ OPTKEYR
__IO uint32_t FLASH_TypeDef::OPTKEYR
Flash Option Key Register, Address offset: 0x08
◆ OPTSR2_CUR
__IO uint32_t FLASH_TypeDef::OPTSR2_CUR
Flash Option Status Current Register 2, Address offset: 0x70
◆ OPTSR2_PRG
__IO uint32_t FLASH_TypeDef::OPTSR2_PRG
Flash Option Status to Program Register 2, Address offset: 0x74
◆ OPTSR_CUR
__IO uint32_t FLASH_TypeDef::OPTSR_CUR
Flash Option Status Current Register, Address offset: 0x1C
◆ OPTSR_PRG
__IO uint32_t FLASH_TypeDef::OPTSR_PRG
Flash Option Status to Program Register, Address offset: 0x20
◆ OTPBL_CUR
__IO uint32_t FLASH_TypeDef::OTPBL_CUR
Flash Current OTP Block Lock Register, Address offset: 0x68
◆ OTPBL_PRG
__IO uint32_t FLASH_TypeDef::OTPBL_PRG
Flash OTP Block Lock to Program Register, Address offset: 0x6C
◆ PRAR_CUR1
__IO uint32_t FLASH_TypeDef::PRAR_CUR1
Flash Current Protection Address Register for bank1, Address offset: 0x28
◆ PRAR_CUR2
__IO uint32_t FLASH_TypeDef::PRAR_CUR2
Flash Current Protection Address Register for bank2, Address offset: 0x128
◆ PRAR_PRG1
__IO uint32_t FLASH_TypeDef::PRAR_PRG1
Flash Protection Address to Program Register for bank1, Address offset: 0x2C
◆ PRAR_PRG2
__IO uint32_t FLASH_TypeDef::PRAR_PRG2
Flash Protection Address to Program Register for bank2, Address offset: 0x12C
◆ RESERVED
uint32_t FLASH_TypeDef::RESERVED
Reserved, 0x64 to 0x6C
Reserved, 0x64
◆ RESERVED0
uint32_t FLASH_TypeDef::RESERVED0
Reserved, 0x48 to 0x4C
◆ RESERVED1
uint32_t FLASH_TypeDef::RESERVED1
Reserved, 0x64 to 0x100
Reserved, 0x70 to 0x100
◆ RESERVED2
uint32_t FLASH_TypeDef::RESERVED2
Reserved, 0x108
◆ RESERVED3
uint32_t FLASH_TypeDef::RESERVED3
Reserved, 0x118 to 0x124
◆ RESERVED4
uint32_t FLASH_TypeDef::RESERVED4
Reserved, 0x140 to 0x14C
◆ SCAR_CUR1
__IO uint32_t FLASH_TypeDef::SCAR_CUR1
Flash Current Secure Address Register for bank1, Address offset: 0x30
◆ SCAR_CUR2
__IO uint32_t FLASH_TypeDef::SCAR_CUR2
Flash Current Secure Address Register for bank2, Address offset: 0x130
◆ SCAR_PRG1
__IO uint32_t FLASH_TypeDef::SCAR_PRG1
Flash Secure Address to Program Register for bank1, Address offset: 0x34
◆ SCAR_PRG2
__IO uint32_t FLASH_TypeDef::SCAR_PRG2
Flash Secure Address Register for bank2, Address offset: 0x134
◆ SR1
__IO uint32_t FLASH_TypeDef::SR1
Flash Status Register for bank1, Address offset: 0x10
◆ SR2
__IO uint32_t FLASH_TypeDef::SR2
Flash Status Register for bank2, Address offset: 0x110
◆ WPSN_CUR1
__IO uint32_t FLASH_TypeDef::WPSN_CUR1
Flash Current Write Protection Register on bank1, Address offset: 0x38
◆ WPSN_CUR2
__IO uint32_t FLASH_TypeDef::WPSN_CUR2
Flash Current Write Protection Register on bank2, Address offset: 0x138
◆ WPSN_PRG1
__IO uint32_t FLASH_TypeDef::WPSN_PRG1
Flash Write Protection to Program Register on bank1, Address offset: 0x3C
◆ WPSN_PRG2
__IO uint32_t FLASH_TypeDef::WPSN_PRG2
Flash Write Protection to Program Register on bank2, Address offset: 0x13C
The documentation for this struct was generated from the following files:
