RTEMS 6.1
FLASH_OBProgramInitTypeDef Struct Reference
FLASH Option Bytes Program structure definition. More...
#include <stm32h7xx_hal_flash_ex.h>
uint32_t OptionType
uint32_t WRPState
uint32_t WRPSector
uint32_t RDPLevel
uint32_t BORLevel
uint32_t USERType
uint32_t USERConfig
uint32_t Banks
uint32_t PCROPConfig
uint32_t PCROPStartAddr
uint32_t PCROPEndAddr
uint32_t BootConfig
uint32_t BootAddr0
uint32_t BootAddr1
uint32_t SecureAreaConfig
uint32_t SecureAreaStartAddr
uint32_t SecureAreaEndAddr
Field Documentation
◆ Banks
uint32_t FLASH_OBProgramInitTypeDef::Banks
Select banks for WRP , PCROP and secure area config . This parameter must be a value of FLASH Banks
◆ BootAddr0
uint32_t FLASH_OBProgramInitTypeDef::BootAddr0
Boot Address 0. This parameter must be a value between begin and end of a bank
◆ BootAddr1
uint32_t FLASH_OBProgramInitTypeDef::BootAddr1
Boot Address 1. This parameter must be a value between begin and end of a bank
◆ BootConfig
uint32_t FLASH_OBProgramInitTypeDef::BootConfig
Specifies if the Boot Address to be configured BOOT_ADD0, BOOT_ADD1 or both. This parameter must be a value of FLASHEx OB BOOT OPTION enumeration
◆ BORLevel
uint32_t FLASH_OBProgramInitTypeDef::BORLevel
Set the BOR Level. This parameter can be a value of FLASH BOR Reset Level
◆ OptionType
uint32_t FLASH_OBProgramInitTypeDef::OptionType
Option byte to be configured. This parameter can be a value of FLASH Option Type
◆ PCROPConfig
uint32_t FLASH_OBProgramInitTypeDef::PCROPConfig
specifies if the PCROP area shall be erased or not when RDP level decreased from Level 1 to Level 0 or during a mass erase. This parameter must be a value of FLASHEx OB PCROP RDP enumeration
◆ PCROPEndAddr
uint32_t FLASH_OBProgramInitTypeDef::PCROPEndAddr
PCROP End address (used for OPTIONBYTE_PCROP). This parameter must be a value between PCROP Start address and end of a bank
◆ PCROPStartAddr
uint32_t FLASH_OBProgramInitTypeDef::PCROPStartAddr
PCROP Start address (used for OPTIONBYTE_PCROP). This parameter must be a value between begin and end of a bank
◆ RDPLevel
uint32_t FLASH_OBProgramInitTypeDef::RDPLevel
Set the read protection level. This parameter can be a value of FLASH Option Bytes Read Protection
◆ SecureAreaConfig
uint32_t FLASH_OBProgramInitTypeDef::SecureAreaConfig
specifies if the bank secured area shall be erased or not when RDP level decreased from Level 1 to Level 0 or during a mass erase. This parameter must be a value of FLASHEx OB SECURE RDP enumeration
◆ SecureAreaEndAddr
uint32_t FLASH_OBProgramInitTypeDef::SecureAreaEndAddr
Bank Secure area End address. This parameter must be a value between Secure Area Start address and end address of a bank1
◆ SecureAreaStartAddr
uint32_t FLASH_OBProgramInitTypeDef::SecureAreaStartAddr
Bank Secure area Start address. This parameter must be a value between begin address and end address of bank1
◆ USERConfig
uint32_t FLASH_OBProgramInitTypeDef::USERConfig
Program the FLASH User Option Byte: IWDG_SW / RST_STOP / RST_STDBY / IWDG_FREEZE_STOP / IWDG_FREEZE_SANDBY / IO_HSLV / SWAP_BANK_OPT
◆ USERType
uint32_t FLASH_OBProgramInitTypeDef::USERType
User option byte(s) to be configured (used for OPTIONBYTE_USER). This parameter can be a combination of FLASHEx OB USER Type
◆ WRPSector
uint32_t FLASH_OBProgramInitTypeDef::WRPSector
Specifies the sector(s) to be write protected. The value of this parameter depend on device used within the same series
◆ WRPState
uint32_t FLASH_OBProgramInitTypeDef::WRPState
Write protection activation or deactivation. This parameter can be a value of FLASH WRP State
