RTEMS 6.1
FLASH Erase structure definition. More...
#include <stm32h7xx_hal_flash_ex.h>
Data Fields | |
| uint32_t | TypeErase |
| uint32_t | Banks |
| uint32_t | Sector |
| uint32_t | NbSectors |
| uint32_t | VoltageRange |
| uint32_t FLASH_EraseInitTypeDef::Banks |
Select banks to erase when Mass erase is enabled. This parameter must be a value of FLASH Banks
| uint32_t FLASH_EraseInitTypeDef::NbSectors |
Number of sectors to be erased. This parameter must be a value between 1 and (max number of sectors - value of Initial sector)
| uint32_t FLASH_EraseInitTypeDef::Sector |
Initial FLASH sector to erase when Mass erase is disabled This parameter must be a value of FLASH Sectors
| uint32_t FLASH_EraseInitTypeDef::TypeErase |
Mass erase or sector Erase. This parameter can be a value of FLASH Type Erase
| uint32_t FLASH_EraseInitTypeDef::VoltageRange |
The device voltage range which defines the erase parallelism This parameter must be a value of FLASHEx_Voltage_Range
