RTEMS 6.1
FLASH Erase structure definition. More...
#include <stm32h7xx_hal_flash_ex.h>
Data Fields | |
| uint32_t | TypeCRC |
| uint32_t | BurstSize |
| uint32_t | Bank |
| uint32_t | Sector |
| uint32_t | NbSectors |
| uint32_t | CRCStartAddr |
| uint32_t | CRCEndAddr |
| uint32_t FLASH_CRCInitTypeDef::Bank |
Select bank where CRC computation is enabled. This parameter must be FLASH_BANK_1 or FLASH_BANK_2
| uint32_t FLASH_CRCInitTypeDef::BurstSize |
CRC Burst Size. This parameter can be a value of FLASH CRC Burst Size
| uint32_t FLASH_CRCInitTypeDef::CRCEndAddr |
CRC End address. This parameter must be a value between CRC Start address and end address of a bank
| uint32_t FLASH_CRCInitTypeDef::CRCStartAddr |
CRC Start address. This parameter must be a value between begin address and end address of a bank
| uint32_t FLASH_CRCInitTypeDef::NbSectors |
Number of sectors to be computed. This parameter must be a value between 1 and (max number of sectors - value of Initial sector)
| uint32_t FLASH_CRCInitTypeDef::Sector |
Initial FLASH sector from which starts the CRC computation This parameter must be a value of FLASH Sectors
| uint32_t FLASH_CRCInitTypeDef::TypeCRC |
CRC Selection Type. This parameter can be a value of FLASH CRC Selection Type
