RTEMS 6.1
FD Controller Area Network. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | CREL |
| __IO uint32_t | ENDN |
| __IO uint32_t | RESERVED1 |
| __IO uint32_t | DBTP |
| __IO uint32_t | TEST |
| __IO uint32_t | RWD |
| __IO uint32_t | CCCR |
| __IO uint32_t | NBTP |
| __IO uint32_t | TSCC |
| __IO uint32_t | TSCV |
| __IO uint32_t | TOCC |
| __IO uint32_t | TOCV |
| __IO uint32_t | RESERVED2 [4] |
| __IO uint32_t | ECR |
| __IO uint32_t | PSR |
| __IO uint32_t | TDCR |
| __IO uint32_t | RESERVED3 |
| __IO uint32_t | IR |
| __IO uint32_t | IE |
| __IO uint32_t | ILS |
| __IO uint32_t | ILE |
| __IO uint32_t | RESERVED4 [8] |
| __IO uint32_t | GFC |
| __IO uint32_t | SIDFC |
| __IO uint32_t | XIDFC |
| __IO uint32_t | RESERVED5 |
| __IO uint32_t | XIDAM |
| __IO uint32_t | HPMS |
| __IO uint32_t | NDAT1 |
| __IO uint32_t | NDAT2 |
| __IO uint32_t | RXF0C |
| __IO uint32_t | RXF0S |
| __IO uint32_t | RXF0A |
| __IO uint32_t | RXBC |
| __IO uint32_t | RXF1C |
| __IO uint32_t | RXF1S |
| __IO uint32_t | RXF1A |
| __IO uint32_t | RXESC |
| __IO uint32_t | TXBC |
| __IO uint32_t | TXFQS |
| __IO uint32_t | TXESC |
| __IO uint32_t | TXBRP |
| __IO uint32_t | TXBAR |
| __IO uint32_t | TXBCR |
| __IO uint32_t | TXBTO |
| __IO uint32_t | TXBCF |
| __IO uint32_t | TXBTIE |
| __IO uint32_t | TXBCIE |
| __IO uint32_t | RESERVED6 [2] |
| __IO uint32_t | TXEFC |
| __IO uint32_t | TXEFS |
| __IO uint32_t | TXEFA |
| __IO uint32_t | RESERVED7 |
| __IO uint32_t FDCAN_GlobalTypeDef::CCCR |
FDCAN CC Control register, Address offset: 0x018
| __IO uint32_t FDCAN_GlobalTypeDef::CREL |
FDCAN Core Release register, Address offset: 0x000
| __IO uint32_t FDCAN_GlobalTypeDef::DBTP |
FDCAN Data Bit Timing & Prescaler register, Address offset: 0x00C
| __IO uint32_t FDCAN_GlobalTypeDef::ECR |
FDCAN Error Counter register, Address offset: 0x040
| __IO uint32_t FDCAN_GlobalTypeDef::ENDN |
FDCAN Endian register, Address offset: 0x004
| __IO uint32_t FDCAN_GlobalTypeDef::GFC |
FDCAN Global Filter Configuration register, Address offset: 0x080
| __IO uint32_t FDCAN_GlobalTypeDef::HPMS |
FDCAN High Priority Message Status register, Address offset: 0x094
| __IO uint32_t FDCAN_GlobalTypeDef::IE |
FDCAN Interrupt Enable register, Address offset: 0x054
| __IO uint32_t FDCAN_GlobalTypeDef::ILE |
FDCAN Interrupt Line Enable register, Address offset: 0x05C
| __IO uint32_t FDCAN_GlobalTypeDef::ILS |
FDCAN Interrupt Line Select register, Address offset: 0x058
| __IO uint32_t FDCAN_GlobalTypeDef::IR |
FDCAN Interrupt register, Address offset: 0x050
| __IO uint32_t FDCAN_GlobalTypeDef::NBTP |
FDCAN Nominal Bit Timing & Prescaler register, Address offset: 0x01C
| __IO uint32_t FDCAN_GlobalTypeDef::NDAT1 |
FDCAN New Data 1 register, Address offset: 0x098
| __IO uint32_t FDCAN_GlobalTypeDef::NDAT2 |
FDCAN New Data 2 register, Address offset: 0x09C
| __IO uint32_t FDCAN_GlobalTypeDef::PSR |
FDCAN Protocol Status register, Address offset: 0x044
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED1 |
Reserved, 0x008
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED2 |
Reserved, 0x030 - 0x03C
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED3 |
Reserved, 0x04C
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED4 |
Reserved, 0x060 - 0x07C
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED5 |
Reserved, 0x08C
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED6 |
Reserved, 0x0E8 - 0x0EC
| __IO uint32_t FDCAN_GlobalTypeDef::RESERVED7 |
Reserved, 0x0FC
| __IO uint32_t FDCAN_GlobalTypeDef::RWD |
FDCAN RAM Watchdog register, Address offset: 0x014
| __IO uint32_t FDCAN_GlobalTypeDef::RXBC |
FDCAN Rx Buffer Configuration register, Address offset: 0x0AC
| __IO uint32_t FDCAN_GlobalTypeDef::RXESC |
FDCAN Rx Buffer/FIFO Element Size Configuration register, Address offset: 0x0BC
| __IO uint32_t FDCAN_GlobalTypeDef::RXF0A |
FDCAN Rx FIFO 0 Acknowledge register, Address offset: 0x0A8
| __IO uint32_t FDCAN_GlobalTypeDef::RXF0C |
FDCAN Rx FIFO 0 Configuration register, Address offset: 0x0A0
| __IO uint32_t FDCAN_GlobalTypeDef::RXF0S |
FDCAN Rx FIFO 0 Status register, Address offset: 0x0A4
| __IO uint32_t FDCAN_GlobalTypeDef::RXF1A |
FDCAN Rx FIFO 1 Acknowledge register, Address offset: 0x0B8
| __IO uint32_t FDCAN_GlobalTypeDef::RXF1C |
FDCAN Rx FIFO 1 Configuration register, Address offset: 0x0B0
| __IO uint32_t FDCAN_GlobalTypeDef::RXF1S |
FDCAN Rx FIFO 1 Status register, Address offset: 0x0B4
| __IO uint32_t FDCAN_GlobalTypeDef::SIDFC |
FDCAN Standard ID Filter Configuration register, Address offset: 0x084
| __IO uint32_t FDCAN_GlobalTypeDef::TDCR |
FDCAN Transmitter Delay Compensation register, Address offset: 0x048
| __IO uint32_t FDCAN_GlobalTypeDef::TEST |
FDCAN Test register, Address offset: 0x010
| __IO uint32_t FDCAN_GlobalTypeDef::TOCC |
FDCAN Timeout Counter Configuration register, Address offset: 0x028
| __IO uint32_t FDCAN_GlobalTypeDef::TOCV |
FDCAN Timeout Counter Value register, Address offset: 0x02C
| __IO uint32_t FDCAN_GlobalTypeDef::TSCC |
FDCAN Timestamp Counter Configuration register, Address offset: 0x020
| __IO uint32_t FDCAN_GlobalTypeDef::TSCV |
FDCAN Timestamp Counter Value register, Address offset: 0x024
| __IO uint32_t FDCAN_GlobalTypeDef::TXBAR |
FDCAN Tx Buffer Add Request register, Address offset: 0x0D0
| __IO uint32_t FDCAN_GlobalTypeDef::TXBC |
FDCAN Tx Buffer Configuration register, Address offset: 0x0C0
| __IO uint32_t FDCAN_GlobalTypeDef::TXBCF |
FDCAN Tx Buffer Cancellation Finished register, Address offset: 0x0DC
| __IO uint32_t FDCAN_GlobalTypeDef::TXBCIE |
FDCAN Tx Buffer Cancellation Finished Interrupt Enable register, Address offset: 0x0E4
| __IO uint32_t FDCAN_GlobalTypeDef::TXBCR |
FDCAN Tx Buffer Cancellation Request register, Address offset: 0x0D4
| __IO uint32_t FDCAN_GlobalTypeDef::TXBRP |
FDCAN Tx Buffer Request Pending register, Address offset: 0x0CC
| __IO uint32_t FDCAN_GlobalTypeDef::TXBTIE |
FDCAN Tx Buffer Transmission Interrupt Enable register, Address offset: 0x0E0
| __IO uint32_t FDCAN_GlobalTypeDef::TXBTO |
FDCAN Tx Buffer Transmission Occurred register, Address offset: 0x0D8
| __IO uint32_t FDCAN_GlobalTypeDef::TXEFA |
FDCAN Tx Event FIFO Acknowledge register, Address offset: 0x0F8
| __IO uint32_t FDCAN_GlobalTypeDef::TXEFC |
FDCAN Tx Event FIFO Configuration register, Address offset: 0x0F0
| __IO uint32_t FDCAN_GlobalTypeDef::TXEFS |
FDCAN Tx Event FIFO Status register, Address offset: 0x0F4
| __IO uint32_t FDCAN_GlobalTypeDef::TXESC |
FDCAN Tx Buffer Element Size Configuration register, Address offset: 0x0C8
| __IO uint32_t FDCAN_GlobalTypeDef::TXFQS |
FDCAN Tx FIFO/Queue Status register, Address offset: 0x0C4
| __IO uint32_t FDCAN_GlobalTypeDef::XIDAM |
FDCAN Extended ID AND Mask register, Address offset: 0x090
| __IO uint32_t FDCAN_GlobalTypeDef::XIDFC |
FDCAN Extended ID Filter Configuration register, Address offset: 0x088
