RTEMS 6.1
FD Controller Area Network. More...
#include <stm32h723xx.h>
__IO uint32_t CREL
__IO uint32_t CCFG
__IO uint32_t CSTAT
__IO uint32_t CWD
__IO uint32_t IR
__IO uint32_t IE
Field Documentation
◆ CCFG
__IO uint32_t FDCAN_ClockCalibrationUnit_TypeDef::CCFG
Calibration Configuration register, Address offset: 0x04
◆ CREL
__IO uint32_t FDCAN_ClockCalibrationUnit_TypeDef::CREL
Clock Calibration Unit Core Release register, Address offset: 0x00
◆ CSTAT
__IO uint32_t FDCAN_ClockCalibrationUnit_TypeDef::CSTAT
Calibration Status register, Address offset: 0x08
◆ CWD
__IO uint32_t FDCAN_ClockCalibrationUnit_TypeDef::CWD
Calibration Watchdog register, Address offset: 0x0C
◆ IE
__IO uint32_t FDCAN_ClockCalibrationUnit_TypeDef::IE
CCU Interrupt Enable register, Address offset: 0x14
◆ IR
__IO uint32_t FDCAN_ClockCalibrationUnit_TypeDef::IR
CCU Interrupt register, Address offset: 0x10
The documentation for this struct was generated from the following files:
