RTEMS 6.1
External Interrupt/Event Controller. More...
#include <stm32h723xx.h>
__IO uint32_t RTSR1
__IO uint32_t FTSR1
__IO uint32_t SWIER1
__IO uint32_t D3PMR1
__IO uint32_t D3PCR1L
__IO uint32_t D3PCR1H
uint32_t RESERVED1 [2]
__IO uint32_t RTSR2
__IO uint32_t FTSR2
__IO uint32_t SWIER2
__IO uint32_t D3PMR2
__IO uint32_t D3PCR2L
__IO uint32_t D3PCR2H
uint32_t RESERVED2 [2]
__IO uint32_t RTSR3
__IO uint32_t FTSR3
__IO uint32_t SWIER3
__IO uint32_t D3PMR3
__IO uint32_t D3PCR3L
__IO uint32_t D3PCR3H
uint32_t RESERVED3 [10]
__IO uint32_t IMR1
__IO uint32_t EMR1
__IO uint32_t PR1
uint32_t RESERVED4
__IO uint32_t IMR2
__IO uint32_t EMR2
__IO uint32_t PR2
uint32_t RESERVED5
__IO uint32_t IMR3
__IO uint32_t EMR3
__IO uint32_t PR3
uint32_t RESERVED6 [5]
__IO uint32_t C2IMR1
__IO uint32_t C2EMR1
__IO uint32_t C2PR1
uint32_t RESERVED7
__IO uint32_t C2IMR2
__IO uint32_t C2EMR2
__IO uint32_t C2PR2
uint32_t RESERVED8
__IO uint32_t C2IMR3
__IO uint32_t C2EMR3
__IO uint32_t C2PR3
Field Documentation
◆ C2EMR1
__IO uint32_t EXTI_TypeDef::C2EMR1
EXTI Event mask register, Address offset: 0xC4
◆ C2EMR2
__IO uint32_t EXTI_TypeDef::C2EMR2
EXTI Event mask register, Address offset: 0xD4
◆ C2EMR3
__IO uint32_t EXTI_TypeDef::C2EMR3
EXTI Event mask register, Address offset: 0xE4
◆ C2IMR1
__IO uint32_t EXTI_TypeDef::C2IMR1
EXTI Interrupt mask register, Address offset: 0xC0
◆ C2IMR2
__IO uint32_t EXTI_TypeDef::C2IMR2
EXTI Interrupt mask register, Address offset: 0xD0
◆ C2IMR3
__IO uint32_t EXTI_TypeDef::C2IMR3
EXTI Interrupt mask register, Address offset: 0xE0
◆ C2PR1
__IO uint32_t EXTI_TypeDef::C2PR1
EXTI Pending register, Address offset: 0xC8
◆ C2PR2
__IO uint32_t EXTI_TypeDef::C2PR2
EXTI Pending register, Address offset: 0xD8
◆ C2PR3
__IO uint32_t EXTI_TypeDef::C2PR3
EXTI Pending register, Address offset: 0xE8
◆ D3PCR1H
__IO uint32_t EXTI_TypeDef::D3PCR1H
EXTI D3 Pending clear selection register High, (same register as to SRDPCR1H) Address offset: 0x14
◆ D3PCR1L
__IO uint32_t EXTI_TypeDef::D3PCR1L
EXTI D3 Pending clear selection register low, (same register as to SRDPCR1L) Address offset: 0x10
◆ D3PCR2H
__IO uint32_t EXTI_TypeDef::D3PCR2H
EXTI D3 Pending clear selection register High, (same register as to SRDPCR2H) Address offset: 0x34
◆ D3PCR2L
__IO uint32_t EXTI_TypeDef::D3PCR2L
EXTI D3 Pending clear selection register low, (same register as to SRDPCR2L) Address offset: 0x30
◆ D3PCR3H
__IO uint32_t EXTI_TypeDef::D3PCR3H
EXTI D3 Pending clear selection register High, (same register as to SRDPCR3H) Address offset: 0x54
◆ D3PCR3L
__IO uint32_t EXTI_TypeDef::D3PCR3L
EXTI D3 Pending clear selection register low, (same register as to SRDPCR3L) Address offset: 0x50
◆ D3PMR1
__IO uint32_t EXTI_TypeDef::D3PMR1
EXTI D3 Pending mask register, (same register as to SRDPMR1) Address offset: 0x0C
◆ D3PMR2
__IO uint32_t EXTI_TypeDef::D3PMR2
EXTI D3 Pending mask register, (same register as to SRDPMR2) Address offset: 0x2C
◆ D3PMR3
__IO uint32_t EXTI_TypeDef::D3PMR3
EXTI D3 Pending mask register, (same register as to SRDPMR3) Address offset: 0x4C
◆ EMR1
__IO uint32_t EXTI_TypeDef::EMR1
EXTI Event mask register, Address offset: 0x84
◆ EMR2
__IO uint32_t EXTI_TypeDef::EMR2
EXTI Event mask register, Address offset: 0x94
◆ EMR3
__IO uint32_t EXTI_TypeDef::EMR3
EXTI Event mask register, Address offset: 0xA4
◆ FTSR1
__IO uint32_t EXTI_TypeDef::FTSR1
EXTI Falling trigger selection register, Address offset: 0x04
◆ FTSR2
__IO uint32_t EXTI_TypeDef::FTSR2
EXTI Falling trigger selection register, Address offset: 0x24
◆ FTSR3
__IO uint32_t EXTI_TypeDef::FTSR3
EXTI Falling trigger selection register, Address offset: 0x44
◆ IMR1
__IO uint32_t EXTI_TypeDef::IMR1
EXTI Interrupt mask register, Address offset: 0x80
◆ IMR2
__IO uint32_t EXTI_TypeDef::IMR2
EXTI Interrupt mask register, Address offset: 0x90
◆ IMR3
__IO uint32_t EXTI_TypeDef::IMR3
EXTI Interrupt mask register, Address offset: 0xA0
◆ PR1
__IO uint32_t EXTI_TypeDef::PR1
EXTI Pending register, Address offset: 0x88
◆ PR2
__IO uint32_t EXTI_TypeDef::PR2
EXTI Pending register, Address offset: 0x98
◆ PR3
__IO uint32_t EXTI_TypeDef::PR3
EXTI Pending register, Address offset: 0xA8
◆ RESERVED1
uint32_t EXTI_TypeDef::RESERVED1
Reserved, 0x18 to 0x1C
◆ RESERVED2
uint32_t EXTI_TypeDef::RESERVED2
Reserved, 0x38 to 0x3C
◆ RESERVED3
uint32_t EXTI_TypeDef::RESERVED3
Reserved, 0x58 to 0x7C
◆ RESERVED4
uint32_t EXTI_TypeDef::RESERVED4
Reserved, 0x8C
◆ RESERVED5
uint32_t EXTI_TypeDef::RESERVED5
Reserved, 0x9C
◆ RESERVED6
uint32_t EXTI_TypeDef::RESERVED6
Reserved, 0xAC to 0xBC
◆ RESERVED7
uint32_t EXTI_TypeDef::RESERVED7
Reserved, 0xCC
◆ RESERVED8
uint32_t EXTI_TypeDef::RESERVED8
Reserved, 0xDC
◆ RTSR1
__IO uint32_t EXTI_TypeDef::RTSR1
EXTI Rising trigger selection register, Address offset: 0x00
◆ RTSR2
__IO uint32_t EXTI_TypeDef::RTSR2
EXTI Rising trigger selection register, Address offset: 0x20
◆ RTSR3
__IO uint32_t EXTI_TypeDef::RTSR3
EXTI Rising trigger selection register, Address offset: 0x40
◆ SWIER1
__IO uint32_t EXTI_TypeDef::SWIER1
EXTI Software interrupt event register, Address offset: 0x08
◆ SWIER2
__IO uint32_t EXTI_TypeDef::SWIER2
EXTI Software interrupt event register, Address offset: 0x28
◆ SWIER3
__IO uint32_t EXTI_TypeDef::SWIER3
EXTI Software interrupt event register, Address offset: 0x48
The documentation for this struct was generated from the following files:
