RTEMS 6.1
This structure registers corresponds to EXTI_Typdef CPU1/CPU2 registers subset (IMRx, EMRx and PRx), allowing to define EXTI_D1/EXTI_D2 with rapid/common access to these IMRx, EMRx, PRx registers for CPU1 and CPU2. Note that EXTI_D1 and EXTI_D2 bases addresses are calculated to point to CPUx first register: IMR1 in case of EXTI_D1 that is addressing CPU1 (Cortex-M7) C2IMR1 in case of EXTI_D2 that is addressing CPU2 (Cortex-M4) Note: EXTI_D2 and corresponding C2IMRx, C2EMRx and C2PRx registers are available for Dual Core devices only. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | IMR1 |
| __IO uint32_t | EMR1 |
| __IO uint32_t | PR1 |
| uint32_t | RESERVED1 |
| __IO uint32_t | IMR2 |
| __IO uint32_t | EMR2 |
| __IO uint32_t | PR2 |
| uint32_t | RESERVED2 |
| __IO uint32_t | IMR3 |
| __IO uint32_t | EMR3 |
| __IO uint32_t | PR3 |
| __IO uint32_t EXTI_Core_TypeDef::EMR1 |
EXTI Event mask register, Address offset: 0x04
| __IO uint32_t EXTI_Core_TypeDef::EMR2 |
EXTI Event mask register, Address offset: 0x14
| __IO uint32_t EXTI_Core_TypeDef::EMR3 |
EXTI Event mask register, Address offset: 0x24
| __IO uint32_t EXTI_Core_TypeDef::IMR1 |
EXTI Interrupt mask register, Address offset: 0x00
| __IO uint32_t EXTI_Core_TypeDef::IMR2 |
EXTI Interrupt mask register, Address offset: 0x10
| __IO uint32_t EXTI_Core_TypeDef::IMR3 |
EXTI Interrupt mask register, Address offset: 0x20
| __IO uint32_t EXTI_Core_TypeDef::PR1 |
EXTI Pending register, Address offset: 0x08
| __IO uint32_t EXTI_Core_TypeDef::PR2 |
EXTI Pending register, Address offset: 0x18
| __IO uint32_t EXTI_Core_TypeDef::PR3 |
EXTI Pending register, Address offset: 0x28
| uint32_t EXTI_Core_TypeDef::RESERVED1 |
Reserved, 0x0C
| uint32_t EXTI_Core_TypeDef::RESERVED2 |
Reserved, 0x1C
