RTEMS
6.1
ETHERNET_PLL_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
ETHERNET_PLL Peripheral Access Layer
MIMXRT1166_cm4.h
struct {
__IO
uint32_t
ETHERNET_PLL_Type::RW
__IO
uint32_t
ETHERNET_PLL_Type::SET
__IO
uint32_t
ETHERNET_PLL_Type::CLR
__IO
uint32_t
ETHERNET_PLL_Type::TOG
CTRL0
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
SPREAD_SPECTRUM
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
NUMERATOR
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
DENOMINATOR
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
CTRL0
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
SPREAD_SPECTRUM
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
NUMERATOR
struct {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
DENOMINATOR
ETHERNET_PLL - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
