RTEMS 6.1
DTS. More...
#include <stm32h723xx.h>
__IO uint32_t CFGR1
uint32_t RESERVED0
__IO uint32_t T0VALR1
uint32_t RESERVED1
__IO uint32_t RAMPVALR
__IO uint32_t ITR1
uint32_t RESERVED2
__IO uint32_t DR
__IO uint32_t SR
__IO uint32_t ITENR
__IO uint32_t ICIFR
__IO uint32_t OR
DTS.
Field Documentation
◆ CFGR1
__IO uint32_t DTS_TypeDef::CFGR1
DTS configuration register, Address offset: 0x00
◆ DR
__IO uint32_t DTS_TypeDef::DR
DTS data register, Address offset: 0x1C
◆ ICIFR
__IO uint32_t DTS_TypeDef::ICIFR
DTS Clear Interrupt flag register, Address offset: 0x28
◆ ITENR
__IO uint32_t DTS_TypeDef::ITENR
DTS Interrupt enable register, Address offset: 0x24
◆ ITR1
__IO uint32_t DTS_TypeDef::ITR1
DTS Interrupt threshold register, Address offset: 0x14
◆ OR
__IO uint32_t DTS_TypeDef::OR
DTS option register 1, Address offset: 0x2C
◆ RAMPVALR
__IO uint32_t DTS_TypeDef::RAMPVALR
DTS Ramp value register, Address offset: 0x10
◆ RESERVED0
uint32_t DTS_TypeDef::RESERVED0
Reserved, Address offset: 0x04
◆ RESERVED1
uint32_t DTS_TypeDef::RESERVED1
Reserved, Address offset: 0x0C
◆ RESERVED2
uint32_t DTS_TypeDef::RESERVED2
Reserved, Address offset: 0x18
◆ SR
__IO uint32_t DTS_TypeDef::SR
DTS status register Address offset: 0x20
◆ T0VALR1
__IO uint32_t DTS_TypeDef::T0VALR1
DTS T0 Value register, Address offset: 0x08
The documentation for this struct was generated from the following files:
