RTEMS
6.1
DMA_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
DMA Peripheral Access Layer
MIMXRT1052.h
__IO
uint32_t
CR
__I
uint32_t
ES
uint8_t
RESERVED_0
[4]
__IO
uint32_t
ERQ
uint8_t
RESERVED_1
[4]
__IO
uint32_t
EEI
__O
uint8_t
CEEI
__O
uint8_t
SEEI
__O
uint8_t
CERQ
__O
uint8_t
SERQ
__O
uint8_t
CDNE
__O
uint8_t
SSRT
__O
uint8_t
CERR
__O
uint8_t
CINT
uint8_t
RESERVED_2
[4]
__IO
uint32_t
INT
uint8_t
RESERVED_3
[4]
__IO
uint32_t
ERR
uint8_t
RESERVED_4
[4]
__I
uint32_t
HRS
uint8_t
RESERVED_5
[12]
__IO
uint32_t
EARS
uint8_t
RESERVED_6
[184]
__IO
uint8_t
DCHPRI3
__IO
uint8_t
DCHPRI2
__IO
uint8_t
DCHPRI1
__IO
uint8_t
DCHPRI0
__IO
uint8_t
DCHPRI7
__IO
uint8_t
DCHPRI6
__IO
uint8_t
DCHPRI5
__IO
uint8_t
DCHPRI4
__IO
uint8_t
DCHPRI11
__IO
uint8_t
DCHPRI10
__IO
uint8_t
DCHPRI9
__IO
uint8_t
DCHPRI8
__IO
uint8_t
DCHPRI15
__IO
uint8_t
DCHPRI14
__IO
uint8_t
DCHPRI13
__IO
uint8_t
DCHPRI12
__IO
uint8_t
DCHPRI19
__IO
uint8_t
DCHPRI18
__IO
uint8_t
DCHPRI17
__IO
uint8_t
DCHPRI16
__IO
uint8_t
DCHPRI23
__IO
uint8_t
DCHPRI22
__IO
uint8_t
DCHPRI21
__IO
uint8_t
DCHPRI20
__IO
uint8_t
DCHPRI27
__IO
uint8_t
DCHPRI26
__IO
uint8_t
DCHPRI25
__IO
uint8_t
DCHPRI24
__IO
uint8_t
DCHPRI31
__IO
uint8_t
DCHPRI30
__IO
uint8_t
DCHPRI29
__IO
uint8_t
DCHPRI28
uint8_t
RESERVED_7
[3808]
struct {
__IO
uint32_t
DMA_Type::SADDR
__IO
uint16_t
DMA_Type::SOFF
__IO
uint16_t
DMA_Type::ATTR
union {
__IO
uint32_t
DMA_Type::NBYTES_MLNO
__IO
uint32_t
DMA_Type::NBYTES_MLOFFNO
__IO
uint32_t
DMA_Type::NBYTES_MLOFFYES
__IO
int32_t
DMA_Type::SLAST
__IO
uint32_t
DMA_Type::DADDR
__IO
uint16_t
DMA_Type::DOFF
union {
__IO
uint16_t
DMA_Type::CITER_ELINKNO
__IO
uint16_t
DMA_Type::CITER_ELINKYES
__IO
int32_t
DMA_Type::DLAST_SGA
__IO
uint16_t
DMA_Type::CSR
union {
__IO
uint16_t
DMA_Type::BITER_ELINKNO
__IO
uint16_t
DMA_Type::BITER_ELINKYES
TCD
[32]
struct {
__IO
uint32_t
DMA_Type::SADDR
__IO
uint16_t
DMA_Type::SOFF
__IO
uint16_t
DMA_Type::ATTR
union {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
int32_t
DMA_Type::SLAST
__IO
uint32_t
DMA_Type::DADDR
__IO
uint16_t
DMA_Type::DOFF
union {
__IO
uint16_t
__IO
uint16_t
__IO
int32_t
DMA_Type::DLAST_SGA
__IO
uint16_t
DMA_Type::CSR
union {
__IO
uint16_t
__IO
uint16_t
TCD
[32]
struct {
__IO
uint32_t
DMA_Type::SADDR
__IO
uint16_t
DMA_Type::SOFF
__IO
uint16_t
DMA_Type::ATTR
union {
__IO
uint32_t
__IO
uint32_t
__IO
uint32_t
__IO
int32_t
DMA_Type::SLAST
__IO
uint32_t
DMA_Type::DADDR
__IO
uint16_t
DMA_Type::DOFF
union {
__IO
uint16_t
__IO
uint16_t
__IO
int32_t
DMA_Type::DLAST_SGA
__IO
uint16_t
DMA_Type::CSR
union {
__IO
uint16_t
__IO
uint16_t
TCD
[32]
DMA - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1052/
MIMXRT1052.h
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
