RTEMS 6.1
DMA Controller. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | CR |
| __IO uint32_t | NDTR |
| __IO uint32_t | PAR |
| __IO uint32_t | M0AR |
| __IO uint32_t | M1AR |
| __IO uint32_t | FCR |
DMA Controller.
| __IO uint32_t DMA_Stream_TypeDef::CR |
DMA stream x configuration register
| __IO uint32_t DMA_Stream_TypeDef::FCR |
DMA stream x FIFO control register
| __IO uint32_t DMA_Stream_TypeDef::M0AR |
DMA stream x memory 0 address register
| __IO uint32_t DMA_Stream_TypeDef::M1AR |
DMA stream x memory 1 address register
| __IO uint32_t DMA_Stream_TypeDef::NDTR |
DMA stream x number of data register
| __IO uint32_t DMA_Stream_TypeDef::PAR |
DMA stream x peripheral address register
